5.4 Triton rebuild questions
Old Apr 11, 2026 | 06:15 PM
Emeraldragon657's Avatar
Emeraldragon657
3rd Gear
Hey all, I have a buddy who had the 5.4 Triton (3 valve) in his 2007 F150 quit a while back. The timing chain wore through the valve cover and it started throwing oil everywhere. He took it to his regular shop and they quoted him $10K for a new engine (they're worried about metal shavings giving the engine too many problems to be worth just replacing the valve cover) which he's not gonna be able to afford anytime soon. I'm mechanically inclined and have torn down a couple engines before, I've been thinking about offering to rebuild his engine for him, but I've never worked on a modular. What things should I be looking out for while i'm in there? Parts that commonly have to be replaced? Factory issues that need to be fixed? I figure I'll do a gasket kit, a set of bearings, and maybe even a re-ring, should I add anything else to the list?
Old Apr 11, 2026 | 06:31 PM
85e150's Avatar
85e150
Welcome to FTE!
Torn down some engine?
Ever put one back together and have it run?
Save your friendship and pass.
This is not an easy or friendly rebuild. Despite the term "modular" there are several versions of these engines and you'll have to map that out to get the right parts.
I could go on but I think you can do some parts searching, check machine shop rates and assess your available tools and work space and find the next step.
Good luck!
Old Apr 11, 2026 | 06:50 PM
Emeraldragon657
3rd Gear
Originally Posted by 85e150
Welcome to FTE!
Good luck!
Yes, I've rebuilt a 351C and it runs quite well, but I imagine that's a bit simpler than a modular. I've also had the cylinder head off a 2003 Audi V6, and rebuilt a T5 manual transmission. I do all my own work on any vehicle I own, don't trust shops not to mess something up, had too many overtorqued wheels and non-leaking engines starting to leak after oil changes, no thank you.
Old Apr 12, 2026 | 06:29 AM
techrep's Avatar
techrep
how many miles on the motor ?
Old Apr 12, 2026 | 07:55 AM
Emeraldragon657
3rd Gear
Almost 300,000k on the 5.4
Old Apr 13, 2026 | 04:43 AM
techrep's Avatar
techrep
I would definitely purchase a reman.
Old Apr 14, 2026 | 01:09 PM
Johnny Paycheck's Avatar
Johnny Paycheck
That chain rub probably sent metal all through the engine while it was still running.
So, to answer what to be “looking out for”…everything that touches oil.
Seconded for a remanned engine unless you need something to occupy your time.
Old Apr 19, 2026 | 07:32 PM
Beechkid's Avatar
Beechkid
IMHO, unless you are looking at a Porshe, Ferrari, etc. engine, it's an engine. Each engine has it's own build specifications but that should not mean in any way that it takes more knowledge to rebuild a modular versus and Windsor engine. The same precautions are going to have to be used with each.... cleanliness is an absolute necessity and plastigage is your friend to ensure whatever the machine shop does to the engine and components is right.
and yes, I own and worked on flatheads, Windsors, modulars......
and given the quality of much of the remain industry, it would be my last choice since the advantage you have here is you know what you have.... whereas the "Remain Industry" has a history of passing on it's "troubles" to the next person who they send the engine to.
mccloudfam1
2004 - 2008 F150
Mar 2, 2022 07:29 PM
Shernius
1997 - 2003 F150
May 13, 2010 07:18 PM
mtgloyd20
Apr 3, 2009 07:21 AM
simptek
Modular V8 (4.6L, 5.4L)
Feb 6, 2009 01:59 PM
