1949 Pass side inner fender acces panel?
Old Apr 3, 2026 | 03:20 PM
Vegastype's Avatar
Vegastype
When bolting the access panel to the main inner fender does the bolt push through the holes from the engine compartment into the wheel well or wheel well into the engine compartment.
Mike
Old Apr 3, 2026 | 06:58 PM
52 Merc's Avatar
52 Merc
The access panel attaches to the main panel from the wheel side, and the bolts holding it in place also go in from the wheel side. This allows access to the valve chest on the 6 cylinder trucks to service the valves. You get to do all of these things together with your head under the fender.
Old Apr 4, 2026 | 06:36 AM
Vegastype's Avatar
Vegastype
Do you happen to know what size bolt or screws are used to hold that panel in place? the bolt kit I have does not have anything for that panel. I will have to go out and purchase the required hardware.
Old Apr 4, 2026 | 09:21 AM
52 Merc's Avatar
52 Merc
The catalog calls out 5/16-18x1/2 which sounds like what I observed last night. The bolt to the frame is a 3/8-24x3/4. It also says to use anti-squeak between the panels. fyi.
Old Apr 4, 2026 | 09:35 AM
Vegastype's Avatar
Vegastype
Thanks!
Martin Torres
15
Sep 27, 2017 11:18 AM
38 coupe
Ford Truck Parts for Sale
May 10, 2012 12:24 AM
50f-1
Apr 21, 2009 03:37 PM
vcamaro42769
Sep 26, 2008 07:46 AM
79'r overhere
Paint & Bodywork
Sep 16, 2007 02:41 PM
