Stalls in every gear.
Old Apr 2, 2026 | 07:33 PM
Heffd's Avatar
Heffd
8th Gear
99 f250 5.4 2v 4x4
Starts and idles perfectly, engages every divit on tree, when in r,d,1,2 barley moves when reving rpms, before stalling, starts right back up repeating every time.
Codes 0500
Inspected wiring harness at every transmission connect, to rear differential. Replaced speed sensor on rear differential, no change in performance.
Code 0500 remains.
Old Apr 4, 2026 | 01:07 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What does "inspected wiring" mean? Is there continuity from one end to the other? Is there a short to ground? Is there a short to power?
How is the trans fluid level? Does it have a burnt smell? Is it red, brown, or black?
Old Apr 6, 2026 | 01:37 AM
Heffd's Avatar
Heffd
8th Gear
Inspected as a n looked them over for skinned or brittle wires and clips from all connects on transmission, transfer case, and rear differential.
Trans fluid is red.no smell, no metal or anything.
Old Apr 6, 2026 | 09:06 PM
Mark Kovalsky
Then you don't know if the wiring is good or bad. You should check what I outlined above.
cterrebonne
Oct 16, 2023 01:50 PM
Wesley Redondo
Modular V8 (4.6L, 5.4L)
Jan 26, 2017 01:38 PM
Psychotrucker
Oct 15, 2011 10:14 PM
