2008 4.6 2V Upstream Hose Disconnected Test Failure
Old Mar 25, 2026 | 10:14 PM
Ol Green 97's Avatar
Ol Green 97
3rd Gear
I have a new to me 2008 F150 Xl 4x4 with the 4.6 V8 2 valve. I am getting a Upstream Hose Disconnect Test failure in Forscan. The value is 0.282. Minimum is -32.768 and maximum is -32.659 according to the Moe 6 Scan. The downstream, stuck open, and egr flow tests are all ok. What is ging on? I replaced the hose that goes to the DPFE sensor. Had vacuum leak there but thats all good now.
Old Mar 26, 2026 | 08:15 PM
projectSHO89's Avatar
projectSHO89
Post the actual DTC (fault code). Probably P04xx or P14xx.
Old Mar 26, 2026 | 10:59 PM
Ol Green 97
3rd Gear
Its not throwing a fault code. Yet anyway. I noticed it in the mode 6 scan after i changed the sparkplugs and a test drive. Here is the EGR section from that scan, [EGR Bank 2]
MID: 32
TID: 82
Value: 0.282 kPa
Min: -32.768 kPa
Max: -32.659 kPa
Downstream Hose Disconnected Test
MID: 32
TID: 83
Value: 0.282 kPa
Min: -3.561 kPa
Max: 32.767 kPa
Stuck Open Valve Test
MID: 32
TID: 84
Value: 0.294 kPa
Min: -32.768 kPa
Max: 4.662 kPa
EGR Flow Test
MID: 32
TID: 85
Value: 14.237 kPa
Min: 1.494 kPa
Max: 32.767 kPa
Everything else passes except the upstream hose disconnect.
Old Mar 27, 2026 | 12:26 PM
projectSHO89
If it's not posting any fault codes, leave it alone. You've gone down a rabbit hole that didn't need to be entered.
Most likely, your PCM needs to be re-flashed to a newer version software that corrects the MIN/MAX limits for MID$32 TID$82. There's a note in the OBDII reference manual (beginning in the '09 edition) regarding this.
Old Mar 27, 2026 | 12:35 PM
Ol Green 97
3rd Gear
Dang rabbits!
Old Mar 30, 2026 | 08:22 AM
torq'ta 5 8's Avatar
torq'ta 5 8
Shoot'em, BillyBob, Shoot'em...
J1MMY
1997 - 2003 F150
Jul 21, 2024 09:23 AM
magicschoolbus
1997 - 2003 F150
Mar 8, 2023 06:30 AM
F150_4x4
1997 - 2003 F150
Jun 8, 2022 05:26 PM
bucktaylor
Jul 14, 2009 06:13 AM
RedBoat
Sep 4, 2007 12:03 AM
