How to torque crank bolt without turning engine?
Old Feb 27, 2026 | 12:55 PM
Mastiff37's Avatar
Mastiff37
All the methods I've read about seem sketchy, like putting rope in a cylinder, or sticking a screwdriver in the flywheel. What do shops actually do? Can I use my impact gun? I won't have control over the exact torque of course, but the range I found (70-90) is pretty wide.
This is for my 1993 with 460.
Old Feb 27, 2026 | 01:13 PM
charlie g's Avatar
charlie g
FTE Community Team
simple use one of these https://www.autozone.com/p/oemtools-...SABEgIGrfD_BwE
Old Feb 27, 2026 | 01:26 PM
Mastiff37's Avatar
Mastiff37
There's an access panel on the bell housing or something like that?
Old Feb 27, 2026 | 03:06 PM
jas88's Avatar
jas88
Yes, you need to remove it and stick a screwdriver into one of the starter gear teeth and pin it up against the bell housing as you turn the motor.
That flywheel turner referenced above will not work on a Ford because the bellhousing goes all the way around the flywheel. A tool like that, you use on a GM.
Old Feb 27, 2026 | 07:23 PM
1Butcher's Avatar
1Butcher
Originally Posted by charlie g
Not with the transmission attached.
I would not follow my lead but at my age, I don't use a torque wrench for hardware like that. It's important for rod/main bearings as well as head bolts, but the rest of them on the engine, I don't. It's what happens when you work on cars for a living.
Old Feb 27, 2026 | 07:28 PM
90project5.0's Avatar
90project5.0
I use my M12 1/2” impact. When it stops spinning, I let off. Knock on wood, so far nor problems.
Old Feb 28, 2026 | 09:13 AM
Hit Man X's Avatar
Hit Man X
Some engine families have actual tools to hold it so you can torque to spec. it is worth a look about
I think on my 302 I just dropped the starter, found an open port in the flexplate and slipped an extension in it.
Old Feb 28, 2026 | 09:18 AM
Mastiff37's Avatar
Mastiff37
"Just" dropped the starter? You are a better man than me. I'm like, "let's button this thing up" and it's looking like a whole big rabbit hole just to torque a bolt... Kind of like, I "just" pulled all the spark plugs to crank over the engine.
I'm really inclined to just impact gun it.
Old Feb 28, 2026 | 09:23 AM
Hit Man X's Avatar
Hit Man X
Well, I have seen items come off vehicles at speed. The starter is easy on the small blocks and my 7.3, no idea on the BBF.
What is the spec anyway?
Old Feb 28, 2026 | 09:24 AM
1Butcher's Avatar
1Butcher
All too often torque specs are given because you can't just say to tighten the bolt. How do you define tight? That is why the factory has torque specs for darn near anything. I worked for a manufacturer that had torque specs for coolant hose clamps. Really? You need to have a torque spec for that? Yeah, because I've seen too many people tighten a hose clamp where it cuts the hose.
I understand that you want to do it right, but the bolt it fairly large and you are concerned about nothing. Don't grab your 1" impact that you use on semi's and don't use the 1/4 drive you use on interior trim pieces. Common sense goes a long way. If you don't have any experience what so ever, use a torque wrench.
Don't follow my lead, everyone knows I am a butcher.
Old Feb 28, 2026 | 09:46 AM
Mastiff37's Avatar
Mastiff37
70-90 ft-lbs is what I got online.
Old Feb 28, 2026 | 09:49 AM
Hit Man X's Avatar
Hit Man X
Do you have access to torque sticks?
They work quite well apparently.
Old Feb 28, 2026 | 09:55 AM
Mastiff37's Avatar
Mastiff37
Man, that's brilliant. Never heard of it, but I may just go over to Harbor Freight and drop the $55 for a set. Would be handy for lug nuts too. I wonder how they work?
https://www.harborfreight.com/12-in-...ece-69870.html
Old Feb 28, 2026 | 10:01 AM
Hit Man X's Avatar
Hit Man X
Discount Tyre near me use them and the Firestone shops, they set initial torque with them and then pass back over with a torque wrench.
Still do and has been near 25 years since I worked at Discount
Unsure how they work, maybe like a torsion bar?
Old Feb 28, 2026 | 10:51 AM
wwhite's Avatar
wwhite
Use the rope trick, clean rope, make sure its on the compression/power stroke.
Simple and cheap.
