1991 f-150 intermittent issues
Old Feb 25, 2026 | 11:42 PM
JacobKeeling's Avatar
JacobKeeling
4wd Low
Unhappy 1991 f-150 intermittent issues
1991 f-150 5.8w automatic
intermittent stalling issues.
losing spark verified that
(whats new)
distributor
tfi
pickup coil
ignition coil
ecm
battery
starter
tfi pigtail
factory and replacement ecm are giving the same issues, so dont know wether or not its ecm related.
known good 5.0 ecm the truck runs like a top, but stalls randomly regardless of engine rpm, like i turned the key off. other "5.8" ecms do the same thing, but it runs bad when it does
Old Feb 26, 2026 | 06:02 AM
90project5.0's Avatar
90project5.0
Verify spark plug wire order on cap. 5.0 and 5.8 use different order.
Old Feb 26, 2026 | 07:24 AM
rla2005's Avatar
rla2005
<snip>
Check the ignition switch on top of the steering column. At this age they are known to split open and/or burn the internal contacts. Very common issue.
Old Feb 26, 2026 | 07:50 AM
wwhite's Avatar
wwhite
known good 5.0 ecm
Quite a few issues here that you are overlooking.
First, have you pulled codes?
Second, you say it looses spark but it runs bad when it does?
Either it looses spark or it does not. How have you determined it is a spark issue, and not a fuel pressure issue?
Last, why are you using a 5.0 EEC? What automatic transmission?
Have you opened up the EEC to check for old/blown components?
Old Feb 26, 2026 | 02:51 PM
JacobKeeling
4wd Low
"runs bad when it does it" means it runs crappy on the 5.8 ecm, but still loses spark
when it dies and wont restart it loses spark, verified no spark to plugs
determined by one pressing schrader valve and fuel spraying out, two the lack of spark
using a 5.0 ecm to see if it changed how the engine ran (it does) not trying to drive the truck with it just trying to fix engine problems
yes, factory and reman unite 5.8 look good.
Old Feb 26, 2026 | 02:52 PM
JacobKeeling
4wd Low
not super tore up about the firing order. sometimes the truck runs great with the 5.8 ecm in it sometimes it dont. it always runs great with 5.0 ecm
Old Feb 28, 2026 | 03:23 PM
DentsideFan's Avatar
DentsideFan
If your using a 5.0 ECM its gonna run lean because less CUI. And you can press a schrader valve at all times but the only way to tell if its getting proper fuel is a pressure gauge. And spark could be the coil being weak. Or something is pulling voltage from your system.
And does it die more often under load? Does it die on idle? How does it sputter out and die? Does it shut off randomly then fire up later? Need a little more info man.
Old Feb 28, 2026 | 09:06 PM
Prototypemech's Avatar
Prototypemech
My first thought. Check your ignition switch. Or hook the "run" wires up to an Incandescent lights bulb and see if the bulb dies when the engine died.
Dinosaurs_Bruh
Mar 3, 2024 08:26 PM
AdrianSmall
May 22, 2012 02:44 PM
Ron ford trucks
Mar 17, 2004 11:49 PM
ls3899
Sep 8, 2003 01:47 PM
