1978 - 1996 Big Bronco
1996 Bronco 302 --> 460 swap.
Old Feb 24, 2026 | 11:36 AM
Delandro's Avatar
Delandro
6th Gear
I am in the works for shoving a built 460 into my bronco. I'm expecting to see ~400hp and 500+ tq. It will be carbed. As I prepare for the project I have some questions:
Has anyone done a swap similar to this? Any tips?
Regarding the fuel system, should I keep the stock EFI fuel pump and add a bypass regulator? If not, are there any reccomended replacement pumps or systems that I should implement instead?
Any radiators for a good price that people have had success with? I've seen a ton of aluminum rads online but many suffer from leakage issues according to reviews. I doubt the stock 5.0 radiator will be able to keep up.
Last, which headers will fit in this application? Will I need custom?
Thanks
For anyone wondering: I have a matching c6 and NP205 transfer case going in with it.
Old Mar 5, 2026 | 10:30 AM
fe390pc's Avatar
fe390pc
Since the F250 was available with the 460, I would look at those parts for use on the Bronco. That should give you all the mounts needed as well as what headers should fit I believe.
Old Mar 12, 2026 | 12:25 AM
Bronco912's Avatar
Bronco912
Jeff's Bronco Graveyard has the motor mounts and headers for the 460 swap. You'll need a adjustable fuel regulator if you're gonna run a carburetor. I suggest you keep the fuel return system intact as well. You'll need it.
Skinut
Engine Swaps
Mar 1, 2016 10:55 AM
shortstuffrm
Mar 11, 2012 09:59 AM
BIGBEARV
Oct 9, 2007 07:53 PM
khadma
Offroad & 4x4
Jul 4, 2007 11:07 PM
Racerrob
26
May 29, 2005 07:13 AM
