How to test 4x4 system without jack stands?
Old Feb 23, 2026 | 12:06 PM
BigFatGuy's Avatar
BigFatGuy
Question How to test 4x4 system without jack stands?
I'm not sure my 4x4 system is working.
In my Bronco, I knew how it felt to turn on 4x4, adn I don't feel that in the Ex... but the issue might be me.
The only way I can think to test the system is to put the truck on 4 jackstands.
Is there any other way I'm not seeing?
Old Feb 23, 2026 | 01:04 PM
John in OkieLand's Avatar
John in OkieLand
if it is in 4x4, and on a solid surface,
a tight turn to the limit, will cause the front tires to start chuffing, grabbing, whatever you want to call it.
if it turns normal, like 2wd, then you have a problem
Old Feb 23, 2026 | 01:44 PM
Excurvelle's Avatar
Excurvelle
Preferably on gravel or grass so you don't snap anything.
Old Feb 23, 2026 | 01:59 PM
Antonm23's Avatar
Antonm23
Put it in 4x4, jack the rear off the ground with a floor jack, see if the truck will move with just the front wheels on the ground.
Assuming you're on concrete the wheels of the floor jack will allow you to move slowly across the surface (lots of inoperable vehicles get moved around the garage with floor jacks and rolling them on the floor jack's wheels).
Old Feb 23, 2026 | 04:17 PM
BigFatGuy's Avatar
BigFatGuy
That's basically what I'm doing now, why I think it's not working... it was a HUGE change in my Bronco.
That sounds like a terrible idea... but it would give me the definitive answer I need.
Thanks, all.
Old Feb 23, 2026 | 04:44 PM
Vinny G-the EX man's Avatar
Vinny G-the EX man
Thanks, all.
it a lot quicker than removing the rear driveshaft!!!
Old Feb 24, 2026 | 04:30 AM
01__Excursion's Avatar
01__Excursion
I don't think any of those ideas tell you if "both" fronts locked.
I would think you could chock the rear wheels, lift the front, vehicle in neutral, E brake on, and rotate by hand each front wheel. If a hub does not lock, it will still free spin by hand.
Old Feb 24, 2026 | 05:32 AM
Freedom-over-safety's Avatar
Freedom-over-safety
Sounds like your front hubs aren’t locking. Here’s what you do. Flip the switch and drive it up and down your street. Park in your driveway and grab a long screwdriver and get down behind the front wheels and try to spin the front axle shafts with the screwdriver by sticking it in the u joint and turning it. If the hubs aren’t locking y ou’ll be able to spin the axle shafts. That’s very common on these due to the vacuum hub system.
Then manually lock the hub on each side and try to turn the axle shafts again. If you can’t, then your transfer case is shifting into 4wd and your vacuum hub system is malfunctioning.
Old Feb 24, 2026 | 10:35 AM
BigFatGuy's Avatar
BigFatGuy
Originally Posted by Freedom-over-safety
Park in your driveway and grab a long screwdriver and get down behind the front wheels and try to spin the front axle shafts with the screwdriver by sticking it in the u joint and turning it..
I'm revealing my own ignorance here, but if the x-fer case is in 4x4 and the hubs are unlocked (which is my suspicion as well), aren't the axle shafts held in place by the transfer case? IOW I should be able to turn the TIRES, but not the AXLE by hand... right?
Old Feb 25, 2026 | 05:57 AM
Freedom-over-safety
Damn, this is what i get for trying to explain something before the caffeine hits. Your’e right. What I should have said was jack up the front end and try to spin each wheel.
The axle shaft test is for when the hubs are possibly not unlocking.
Old Feb 25, 2026 | 09:09 AM
Antonm23's Avatar
Antonm23
Perhaps it is for someone that isn't familiar or comfortable with garage work. Literally every day cars are moved around just about every shop in the world being rolled on floor jack wheels, it a very common practice. Yes there is risk involved, but its not hard (you just don't attempt to roll over obstacles or seams in the concreate), and if your average garage hourly laborer/ mechanicals helper type employee can manage to figure it out and do it successfully, well,,, it can't be that hard.
The next easiest method would be if you have the center caps removed from the rear wheels (or have wheels that don't have center caps), just pull the rear axle shafts out. The sterling 10.5 rear end in these things is a full-float rear end, meaning the axle shaft can be removed with the vehicle on the ground without disturbing the wheel bearing. Don't even have to lay on the ground or get under the truck to remove the rear axle shafts (but it will be stinky and slightly messy as the shafts will be coated in gear oil).
Old Mar 3, 2026 | 04:16 PM
85e150's Avatar
85e150
Please keep the discussions civil and review the guidelines if need be:
https://www.ford-trucks.com/site-guidelines/
tazmans
1983 - 2012 Ranger & B-Series
Jan 27, 2016 10:26 AM
Sudsrat
1997 - 2003 F150
May 29, 2005 09:48 PM
DieselR6
1997 - 2003 F150
Jan 14, 2005 08:48 PM
