Why is there engine noise in my back speaker only?
Old Feb 18, 2026 | 04:25 PM
1998Ranger25L153CID's Avatar
1998Ranger25L153CID
I got his 98 Ranger with a later premium cd, cassette, radio that worked good for awhile. It still works good but I hear engine noise in the speaker right behind the seat. It's a regular cab with 4 speakers. I replaced the speaker behind me with a brand new Ford one thinking it maybe the speaker but it didn't go away. If you change to any of the other 3 speakers it doesn't come through them, just normal sound. Even if I try to turn the sound just to the front, you can still hear engine noise coming from that one speaker. I thought it maybe the radio noise capacitor bolted to the coil pack so I replaced that with a new Ford piece. Nothing changed. Is there something I'm missing? Is the radio bad? I have 2 80-Watt Premium am/fm/cd/cassette rds radios that work but the screens are dead so I haven't tried installing them. I was going to send one off and get it refurbished. I had an aftermarket cd player in the truck for years but I like that factory radios.
Old Feb 18, 2026 | 05:09 PM
BareBonesXL's Avatar
BareBonesXL
You mean a buzz that varies with engine RPM? Is it slow, like a single cylinder or fast like all four? Could be plug or wire.
Alternators can put out a buzz also.
Old Feb 19, 2026 | 08:41 AM
TopsailBeachBum's Avatar
TopsailBeachBum
Just for S&G, the first thing that came to mind was the ground to the speaker. Could you attach a jumper from the ground tab on the speaker to a metal body part on your truck just to see if it goes away? Might be a waste of time but it might not too.
Old Feb 19, 2026 | 11:33 AM
tomw's Avatar
tomw
You could have a damaged wire between the radio head and the noisy speaker. The ground/return might have to take a roundabout way back to the audio source, such as underhood and across the engine somewhere. It could then pick up RF from underhood contributors... and leak that noise into the radio/audio.
To eliminate that possibility, I would check the resistance of the return wire end-to-end, and to ground at the speaker end. If there is a break, ohms would be whacko, if it routes through underhood areas, the ohms would not make sense. If it ohms out correctly, never mind.
tom
Old Feb 19, 2026 | 03:50 PM
1998Ranger25L153CID
The noise doesn't change with increase in RPM. It dissipates sometimes and sometimes you can't hear it. If you ever watched the Jetsons cartoon it actually sounds like a Jetsons car. Sometimes it's more prevalent than others. I actually haven't tried unplugging that speaker and running 3 speakers. That's what I was thinking of trying to test it out. I can inspect the wires while I'm there too.
Old Feb 20, 2026 | 09:04 AM
tomw's Avatar
tomw
If the noise is constant frequency, then it likely does NOT come from an engine component. It is more likely a failing component that is directly in the LR autio output circuit. A failing/failed capacitor could allow buzzes into the audio output. To fix that requires instruments and a workstation that is unavailable to most. You could take it to a radio repair shop.... If you can find one.
More likely, if it is OEM, finding a used unit from a boneyard is more likely to result in a normally operating audio system. Unless it is one of the 'up market' audios, such as B&O, Bose, Altec, etc, the cost
from a boneyard is generally less than having a shop attempt a repair. I cannot quote prices, but car dash part dot com .. likely has whatever you need, and can locate by geograpic area.
tom
Old Feb 20, 2026 | 09:36 AM
BareBonesXL
If you can switch leads at the head unit that will tell you if it's that or the wiring to the speaker. Probably difficult but might be possible. Depinning maybe.
Chug-Chug
Oct 29, 2021 07:55 AM
Nathan00
Electrical Systems/Wiring
Dec 19, 2014 12:19 PM
phoneman91
Dec 14, 2007 10:22 AM
BeejPlayBass
Jan 3, 2005 09:15 PM
