Gas Cap Loose …
Old Feb 8, 2026 | 09:32 PM
Rusty Bucket Ohio's Avatar
Rusty Bucket Ohio
Gas Cap Loose …
So I have a 2003 Ranger, 2.3 , 5 speed, 230k miles … my first time with something that has a working computer and a diagnostic plug. I just replaced the MAF sensor after Oreileys scanner said most likely and it does run Wwaayy better now… but check engine light came back on after about 30 miles and now the gas cap light is on again … a few months ago it came on and O’reileys said replace the gas cap which I did but since then the light will come on and off intermittently … my question is … in the evap system is there anything else that can give the gas cap reading and light to come on or did I get a faulty gas cap and I should get another ? I can feel a slight miss when the light comes on and seems to have less power too … anything else I should look for ?
Old Feb 11, 2026 | 11:08 PM
BareBonesXL's Avatar
BareBonesXL
I would read the actual code. There are different types of Evap system faults.
Sounds like you have a small leak, that is not permanent since it was gone for a while. That could be a sticky valve. But you need to do some diagnostic work before swapping parts.
This guy does a great job of finding problem sources. Worth watching a few videos.
https://www.youtube.com/@SouthMainAu...rch?query=evap
Old Feb 12, 2026 | 07:44 PM
Rusty Bucket Ohio
Thank You … the light went off again today 🤷
I will watch this guy for sure …
Watcher58
Aug 19, 2021 06:30 AM
ctguy
Feb 5, 2009 12:53 PM
1984F15016
Jan 23, 2008 05:55 PM
bartamos
1997 - 2003 F150
17
Dec 13, 2006 03:16 PM
glennbobg
1997 - 2003 F150
Sep 9, 2004 11:13 AM
