Salvage rearend
Old Feb 6, 2026 | 08:54 PM
zman764's Avatar
zman764
Salvage rearend
A couple years ago my factory limited slip started going bad and the shop I took it to replaced the whole rearend with a salvage open rearend.
I want to get a limited slip back in and I’m wondering. If I go to a yard and buy an entire used rearend with a limited slip. How likely is it that the unit would being it’s way out? What’s the mileage I want to stay under? If I just get the wheels off the ground and make sure both wheels spin the same direction when I turn one wheel is that enough to know that it’s not bad before buying?
Old Feb 7, 2026 | 10:32 AM
Hoghntr's Avatar
Hoghntr
Trailering
Have you looked at a new Eaton power track from summitracing that way you know you have a good fresh one
Old Feb 7, 2026 | 10:53 AM
zman764's Avatar
zman764
Yes, installing a new LSD is beyond my skill set but swapping the entire reared isn't. Local shops are quoting around $2,000 to install a new LSD but I can find a salvaged reared for well under $1,000.
Old Feb 7, 2026 | 05:23 PM
Hoghntr's Avatar
Hoghntr
Trailering
Gotcha, scrap yards are getting ridiculous with there inventory. Example my transmission went out In my 2007 f150 5.4 fx4 and I can't rebuild one but I can swap one out, so I called around and the going rate was $1800_$2000 for one with 150k + miles on it! So I got a ATK remand from jegs with new torque converter and fluid for $2100. Just mind blowing 🤯 have you searched car-part.com it gives you access to every salvage yard in the United States
Old Feb 7, 2026 | 09:18 PM
Johnny Paycheck's Avatar
Johnny Paycheck
Just go aftermarket. The clutches in the factory Trac-lok aren’t the greatest and you have that friction modifier to deal with as well.
I did look briefly at them, but I hear lunchbox lockers may be worthwhile.
Either way, those quotes you’re getting must be the “we don’t need the work” quotes.
Old Feb 8, 2026 | 09:45 AM
WWR's Avatar
WWR
So much this. The factory CrapLok is useless. In practice it's an open diff -- no reason to seek one out.
Lunchbox lockers are a different world, though. Typically noisy and kinda abrupt. If you need absolute no-nonsense traction, though, they'll do it. If it's a pavement princess a quality limited slip is the ticket, and that is most definitely not OEM.
Old Feb 8, 2026 | 12:38 PM
zman764's Avatar
zman764
I definitely want quality limited slip. Smooth engagement and disengagement. Don’t want it to be snappy or harsh.
Old Feb 10, 2026 | 09:53 AM
tbear853's Avatar
tbear853
At one end you have the open rear. It's smooth. It works very well on pavement, curves and straights. It provides power to both rear wheels the same, always limited to the power handling capability of the one with least traction.
At the other end you have the spool. It's smooth in operation as all it does is lock the axles together like one but they don't work so well on pavement, curves, etc.
Any track loc or posi, locker, etc. is gonna fall in between the two, they are engineered attempts to combine the best of both, they will never be perfect by every users notion of perfect operation in all uses. A user control will let the user best tailor operation to the moment.
You could modify one to immitate a spool, or just modify one so only one drive wheel will always do the pushing.
Old Feb 25, 2026 | 09:59 AM
Hoghntr's Avatar
Hoghntr
Trailering
I would get a Eaton power Trac LSD. Watch a good video on YouTube how to do it. The job is not hard
BII Plow Truck
Apr 9, 2025 05:43 PM
jimdandyf100
Dec 30, 2012 05:46 PM
eco
Mar 26, 2007 02:39 PM
karljay
13
Mar 14, 2006 10:48 PM
X GM GUY
Apr 6, 2005 10:14 AM
