I’m about to deal with my leaking oil cooler and while it’s off was considering doing my exhaust manifold (s), It doesn’t appear to be leaking, but they look in pretty bad shape. Am I better off buying used OEM on eBay, sending them to be machined and running no gasket, or are people having any luck with new Dorman or others and running with a gasket?
I would rather OEM machined square, I need to do that also and I plan to use gaskets. Agreed with aftermarket may not take the heat, pun intended
Prepare to lose coolant when doing the oil cooler, most of us use that precharged brand Fleetcharge that is purple. You can also catch as much of yours as possible, reuse, then adjust the SCA levels. Judgement call on your end!
So even with machined OEM you recommend using gaskets, I thought the purpose of OEM was to rely on the machined surface and not have the potential for gasket leaks?
As for the coolant, the system needs to be drained first but the mess of falling fluid is from what can’t be drained from the oil cooler part of the system, correct?
Well, I planned to use gaskets as I figure the head's exhaust ports are not perfect either. Just a CYA thing to me
There is going to be a nice amount of slop with the oil cooler removal. Pick up some cardboard boxes to let that stuff fall all over and then can just toss that crap in the bin after. Even if you drain the system the best you can, the cooler is one of the lowest places on the block as I recall.
Nice tip, I can’t tell you the number of times “the volume “ has exceeded “the receptacle” in my shop.
I was hoping to find some OEM units to have finished and machined in order to minimize down time.
If ‘94-‘03 gaskets will work, does that mean the manifolds are a direct swap too (up to ‘03, mines a ‘97)?
Consider a coolant filter while apart, many of us have posted pics on here of the crapola that comes out.
I can look up the PNs for a basic one, I went with Dieselsite on the 7.3. Basic is just a Wix base and filter that I have on both 5.4s on the heater core supply hose. Work wonders on neglected systems.
Cement trough is what i use. 8 gallons wont fill it up.
Gaskets swap ok, manifold is different S-Duty pass side manifold has a slightly longer outlet at the rear of the manifold
Multiple pans can make this easy. Pan 1 is like you alway did. Hold pan two over pan one and catch the first gallon or whatever is comfortable. Set pan 2 aside and grab pan 3, repeat as needed. I've been using dollar store pans for this. The pans are cheap and great to have around for all purposes, get a few extras. They have cheap disposable buckets too.
Broken exhaust studs are the worst. Forty years ago or so, I knew a guy who could burn them out of a head. He said it was more about oxidation than heat. Never learned how to do that myself. He was a great old Rust Belt Yankee.
Man that is high concept, I love it.
Might go down to Harbor Freight and see what they have.
