4.6 fuel leak
Old Jan 17, 2026 | 05:36 PM
1mack's Avatar
1mack
1st Gear
4.6 fuel leak
new here. have a 1992 Lincoln 4.6. fuel leak problem. first a injector popped out, fix, then leak on fuel line at the rail -fix then pressure test port leak the the thread to the rail. could i have a bad pressure regulator ?
Old Jan 20, 2026 | 02:00 PM
G2IC_Wraith's Avatar
G2IC_Wraith
Anything is possible but these parts are getting up there in years.
You won't know unless you can get an accurate pressure at the rail if you have a Schrader valve on the rail.
Rcemaxx
Sep 23, 2023 10:14 PM
Copedawg
19
Feb 7, 2011 09:10 PM
jim6liter
Jan 12, 2009 05:03 PM
Scott89-150
Jan 20, 2007 11:49 AM
gomfrddy
Nov 27, 2005 04:14 PM
