Tires and wheels
Old Dec 31, 2025 | 10:55 AM
Theboneskes's Avatar
Theboneskes
Tires and wheels
Looking at a set of wheels and tires for my 2003 Excursion 2WD, will 265/60/20s fit? Or is a 275/50/20 ok? Not sure how wide we can go?
Will a set of Vision Spider wheels fit ok, and are strong enough especially towing? Im looking at 20x9 with a +12 offset, and a backspace of 5.47. Is that correct?
I know how to find tire size and see that they are the same width as factory, but is the height ok? Not sure whats to high for these trucks. Thank you
Old Dec 31, 2025 | 11:26 AM
Jimmy's Pilot Service's Avatar
Veteran: Navy
https://tiresize.com/comparison/
^^^^^^ May help you see the picture better.
The 265/75R/16 is the stock on the trucks for that year series, other than the rim, you are close to the same size with 265/60R/20.
Going with the 275/50R/20 option you will loose some of the economy as it is a bit shorter and wider, the wider adds rolling resistance... Enough to for most to notice, maybe not. You will gain a bit of low end out of the hole performance as well. Your RPM's will go up in cruise.
Old Dec 31, 2025 | 12:14 PM
bwguardian's Avatar
bwguardian
I run a 275/70/18 on stock 2004 18x9 wheels on the wife's 2wd Excursion and there's plenty of clearance. These tires are .7" taller and .4" wider than the 265/60/20 you're looking at. The key will be in the wheels offset, and I'm not sure what stock is. I like the wheel/tire setup on it as it fills up more of the fender well.
Old Dec 31, 2025 | 05:31 PM
Vinny G-the EX man's Avatar
Vinny G-the EX man
^^^ I agree with bwguradian , I also run 275-70/18 on 04 HD rims on my 03 4x4 with no clearance problems and they fill the well better. You should have no problems.
Old Jan 1, 2026 | 04:29 PM
Theboneskes
Can I see a picture of the rims you have? Just curious. Ill assume for a 2004 F250/350 Harley Davidson edition 18" wheel?
Old Jan 1, 2026 | 05:31 PM
bwguardian's Avatar
bwguardian
There's those, the King Ranch, and Lariat editions...there's another Ford SVO?, but the chances of finding those are rare. However, they're all going to be 18"x9" factory offset wheels. I have the King Ranch editions on the wife's Excursion and the Lariat editions on my F350...
Old Jan 2, 2026 | 12:22 AM
Vinny G-the EX man
Here you go
Old Jan 2, 2026 | 05:21 PM
WE3ZS's Avatar
WE3ZS
And here are the ‘04 Lariat 18”X8” wheels with 305/70R18s (35.25”X12.8”) tires.
Old Jan 4, 2026 | 06:14 AM
01__Excursion's Avatar
01__Excursion
Those are the rims that came with the parts X I bought, now I know they are Lariat rims.
Old Jan 4, 2026 | 09:34 AM
WE3ZS's Avatar
WE3ZS
Silver painted spoke pockets on the Lariats and tan/gold on the KR version.
Old Jan 4, 2026 | 04:30 PM
01__Excursion
Black pockets and drums and silver on my version..
Old Jan 4, 2026 | 06:08 PM
Theboneskes
Ive been looking at these rims, thinking of going with them with 285/60/18 LT tires, which would be 20mm wider than stock, and circumference is .6" smaller, so speedo would be .4 MPH off at 60 MPH
https://ebay.us/m/qpeQC5
Old Jan 5, 2026 | 12:11 PM
Theboneskes
Although have found these now too and alot cheaper. To many choices!
Old Jan 5, 2026 | 05:18 PM
01__Excursion
Those look better...
Old Jan 6, 2026 | 03:45 PM
Theboneskes
Whoever is was sold those XD wheels, looking at these now... 2017 King Ranch wheels. 20" with stock Cooper tires that are 275/65/20 I think? Our stocks have a 12mm offset and those are 40mm offset. The guy had them on a 2007 F250 and said they didnt rub.
