Offroad & 4x4
1990 f150 lift
Old Dec 2, 2025 | 01:54 PM
Bzman's Avatar
Bzman
1st Gear
1990 f150 lift
I’ve got a 1990 4x4 that’s gonna be a frame off resto built to look like it was built in the 90s custom graphic paint and all. I’d like to put a 8 inch lift under it and run 37s or 40” big ol balloon tires on a 15 or 16” rim. Does anyone have any experience with an 8” lift on one of these trucks it’s a single cab short bed. Is there anything I should be concerned about should I solid axle swap it? Truck won’t be used to really off-road or any thing to crazy more or less will be a show truck. Or do you guys think it’ll look weird being that high while being a single cab short bed. Any input is appreciated and welcomed
Old Dec 4, 2025 | 10:08 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
8" off the shelf is going to be hard to find, most common amount is 6". Isn't that a TTB front axle? Then yea solid axel swap is a good idea.
Atlas Suspention has rear spring options. https://www.atlassuspension.com/1980...e-Rear-Springs
That is alot of lift for a 1/2 ton SB, probably going to have to relocate the rear axle leaf springs pads to get a better pinion angle. I do not think pinion shims will be enough. Probably a new rear drive shaft and alot of other little items to think about. Ebrake cables, brake lines ect...
6" https://www.jackit.com/bds-508h-conf...gaAu2eEALw_wcB
$$ for the front. https://desolatemotorsports.com/prod...C61wlS3XBjfa8E
Old Dec 5, 2025 | 07:41 AM
tjc transport's Avatar
tjc transport
i ain't rite
with 8 inches of lift, i would think both driveshaft will need to be lengthened, plus front and rear soft brake lines.
GeoffVB
13
Jan 12, 2025 05:35 PM
Kodiak660
13
Oct 19, 2012 10:29 PM
BlueFordBabe
Nov 22, 2005 03:06 PM
fordman16b
Jul 21, 2005 01:12 PM
bucks-heritage
3.8 & 4.2L V6
61
Nov 1, 2004 08:23 AM
