Hello,
I changed new engine for my truck, started the engine, after a few time it wont start anymore, replaced the battery, still was not starting for a few days, then Saturday started, run perfectly, I drove the truck without any issue,let it work for couple hours, today I started in the morning all good, then I
turned off and when I wanted to start it again it wont start again,
after the scanner I got this codes:
B10D9:87-08 PATS(Passive Anti-theft System) Transponder
B10D7:87-08 PATS(Passive Anti-Theft System) Key
P0230:14-08 Fuel Pump Primary Circuit
B12310:14-08 Run Start Control.
Please advise how to fix the issue that it is stopping it from starting.
My first thoughts are: I would drive to my local vehicle key specialists and have them check and or reprogram the keys. They should be able to check and see if you have some kind of glitch, explain it to you, then reprogram current keys.
Just a guess while I am sitting way over here on my computer.
