Modular V10 (6.8l)
Normal sounds or an issue?
Old Oct 24, 2025 | 10:31 PM
Mykah knabe's Avatar
Mykah knabe
Over the past few months, ive noticed some extra mechanical noise on my 05 v10. Now im not confident these are new, just that I just recently noticed them. They sound like very subtle ticks, clicks, and other mechanical sounds. They aren't very loud. Also ive noticed a louder combustion sound when cold. When the rpms finally drop to around 1000, I hear almost like extra combustion, not a miss fire exactly. Its extremely hard to explain so I might post a video later. Anyway am I likely ok and just paranoid or should I look into these things?
Old Oct 26, 2025 | 12:48 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Could be either or both depending on your hearing and the actual sounds. I'd say post a video or audio that actually captures the sound well and we'll be able to help figure it out.
Is the oil full?
Has it had any work done to it recently?
Old Oct 26, 2025 | 12:59 AM
Mykah knabe
Oil is good. No recent work. Ill post a good video tomorrow.
Old Oct 27, 2025 | 09:57 AM
charlie g's Avatar
charlie g
FTE Community Team
that will for sure help us ,help you pin point the issue
Old Oct 27, 2025 | 10:10 AM
Mykah knabe
Havent had a chance to get a video yet. Ill post sometime this week.
Old Oct 27, 2025 | 09:25 PM
Mykah knabe
Finally got around to getting a video of both the sounds from under the wheel well and the exhaust.
Now its hard to hear the sounds im describing in the video, but the main ones are: combustion sound is sounding different then normal, and there's also a very quiet tick that goes tick tick tick tick tick, pause, repeat. (I know the louder tick that happens once every 10 seconds is the a/c, thats not the one im talking about)
I Probably sound stupid and paranoid lol.
Old Oct 28, 2025 | 08:07 PM
riderboy1961's Avatar
riderboy1961
What is the mileage?
How long have You owned the rig?
Then I have a better idea on how the truck has been used, towing or not, heavy foot on gas pedal all the time, things like this.
These are a couple things I personally would be knowing in order to move forward on troubleshooting.
Wouldnt hurt to check the Spark Plugs that they are snugged into the spark plug holeand are at the proper torque too.
Old Oct 28, 2025 | 10:47 PM
Mykah knabe
It has 138k. Been in the family since brand new in 2005. Its been meticulously maintained the entire time. It used to tow a 4 horse, goosneck horse trailer and around 4-5 tons of hay every few months. Performance is good with no jerks, gutless feeling, or trouble reaching 60 mph when towing.
Spark plugs were changed around 100k, and they are definitely all in place. Also the timing chain sounds i thought i was hearing a few months ago turned out not to be the timing chain, as i found a video of a cold start from 8 years ago and it sounds the same.
Old Oct 28, 2025 | 11:51 PM
CathedralCub
FTE Community Team
I don't hear anything unbecoming. Good to have the AC compressor cycling as it gives us a reference of the video's sound levels.
As mechanical fans got quieter, and then changed to electric, it gave us less cover for other noises . . . noises that we wouldn't have heard otherwise. Then, engines started adding stuff that makes more noise like overhead cams and direct injection.
Maybe that's part of what's going on here?
Old Oct 29, 2025 | 10:14 AM
Mykah knabe
It must just be normal sounds im hearing, but I think ill take the valve covers off at the next maintenance interval, just to check if theres sludge, loose parts, or severe wear. thanks for the help.
Old Oct 29, 2025 | 11:17 PM
CathedralCub
FTE Community Team
When you do take it apart, I think we'd all be curious what you find!
Old Nov 2, 2025 | 04:04 AM
charlie g's Avatar
charlie g
FTE Community Team
sounds totally normal to me,
Rob89
Dec 13, 2021 10:06 AM
David Lanterman
2015 - 2020 F150
Jan 27, 2021 11:42 AM
onug
2015 - 2020 F150
Apr 10, 2016 09:41 PM
JerrySC
3.8 & 4.2L V6
Jan 27, 2008 11:19 AM
5.4XLT
Modular V8 (4.6L, 5.4L)
Oct 20, 2007 07:13 AM
