Machine shop screw up, need advice.
Old Sep 21, 2025 | 08:47 PM
unibody62's Avatar
unibody62
I had my 292 y-block bored out and new cam bearings installed several years back, planning to put in the truck I have been rebuilding. I reassembled the engine myself and then life happened, so I put it on the back burner. When I got it running recently and went to adjust the tappets, I discovered I’m not getting oil to the top end. After some research I’m sure they installed the bearings wrong. What does everyone recommend, try and install new bearings in the truck or pull the engine and do it? Bear in mind, although I have rebuilt a few engines, I’ve never done cam bearings before. I know I’d need a tool, hopefully I could rent one. Although I won’t be able to tackle this until next spring due to other irons in the fire (and no heat in my garage), it’s on my mind and I’m trying to formulate a plan. I may have to consider letting a shop do it also. I tried to find an answer on YouTube but there doesn’t seem to be a pertinent video.
Old Sep 23, 2025 | 04:32 PM
ManFordman2's Avatar
ManFordman2
I do believe that the lifters will be the main problem.You will want the engine upside down to keep the lifters from falling down as you slide the cam out. According to my "ford y-block engines" book, the cam and lifters are the last components to be removed from a y block.
Old Sep 23, 2025 | 07:36 PM
unibody62's Avatar
unibody62
I have a Ford shop manual, it seems like it says the engine doesn’t have to be removed, if I’m reading the section correctly. I think they should pop up enough to pull them as you rotate the cam. I’m more worried about if I’m capable and if there is room to manipulate the tool to install bearings. When I look at it again, I’m going to remove the rocker arms and see if there is a reason for the lack of oil. I could swear I checked for oil coming up before I installed them. I was running the pump with a drill.
Old Sep 25, 2025 | 01:32 PM
Crop Duster's Avatar
Crop Duster
You cannot replace the cam bearings with the engine in the truck. There is a core plug on the rear of the engine that must be removed to gain access to the bearings. If you do not have the proper tool and some experience you will likely ruin the new bearings trying to install them yourself.
It would be a 1 in 100 chance the shop installed the bearings wrong. Did you pre-oil the engine? How long did you run the engine? It can take some time for the oil to reach the rockers if the system wasn't primed.
Old Sep 25, 2025 | 08:47 PM
unibody62's Avatar
unibody62
Thanks for the reply. I did pre-oil with a drill and I know it had to be reaching the rocker area. I’m just wondering if the passage is plugged in the rocker arms. I’ll pull the rocker arms and try to figure it out. As mentioned, I have good pressure so the only possible damage would be the rocker arms. My 49 year old son is seriously ill with a brain tumor so I have a little too much going on think about really getting into it. He and his family are 6 hours from me, so I try to go help out when I can. If I have to put new bearings in and the engine needs pulled, I guess I’ll get to it when I can.
rpatrick
Jun 16, 2011 08:06 AM
madrox
Dec 31, 2009 07:28 PM
Keiff
Jul 29, 2007 10:46 AM
ford390gashog
Aug 3, 2004 02:05 AM
unioncreek
Mar 11, 2002 09:58 PM
