CCV delete fittings needed - with out hoses
Old Dec 8, 2024 | 10:59 AM
speakerfritz's Avatar
speakerfritz
Looking for a ccv delete kit of just the fittings . I already have 20 ft of hoses.
been checking around and all I can find are complete kits with hoses.
any leads
Old Dec 8, 2024 | 12:38 PM
Overkill2's Avatar
Overkill2
any leads
Yeah what sizes....?
I may or may not have done some research with my impending install of the new catch can....
Old Dec 8, 2024 | 01:51 PM
speakerfritz
I have a 20 ft 1" hose.
if everything is 7/8 fitting...I'll just use a rubber bushing to absorb the extra 1/8 .
Old Dec 8, 2024 | 02:01 PM
Overkill2's Avatar
Overkill2
I was actually talking about the thread sizes. I can help you find fittings but not sure about that adapter plate shown... the port sizes on my new can are -12AN ORB which are pretty big ports... when I get home later, I'll post a link or two for you.
Old Dec 8, 2024 | 06:49 PM
Overkill2's Avatar
Overkill2
Hey Fritz for the fittings themselves try here...
https://www.anhosefittings.com/
Here's a cheaper kit but I'll see what I can dig up for you...
https://flasharkracing.com/products/...roduct-reviews
Real cheap... made in Chicom...
https://jcarpart.com/products/2011-2...20group%20%231
Old Dec 8, 2024 | 08:17 PM
WK15's Avatar
WK15
https://propowerdiesel.com/products/...rd-6-7-ccv-kit
Old Dec 9, 2024 | 07:22 AM
Overkill2's Avatar
Overkill2
Came across that one as well but much more $$$.
Old Dec 9, 2024 | 07:47 AM
speakerfritz
So far these kits are either just a connect fittings with no block plates or complete kits .
i guess block plates, connect hardware, minus hoses doesn’t exist.
Old Dec 9, 2024 | 08:00 AM
JoeUser's Avatar
JoeUser
You could get it from fleaBay: https://www.ebay.com/itm/126816006510
Negotiate an offer, and just use what you need from the kit.
Old Feb 5, 2025 | 02:51 PM
Ed in Maine's Avatar
Ed in Maine
Hey Fritz - What did you end up doing on this? I see kits out there in 150 range. The SPE has the drip catch milled piece. I am way too late on doing this and will be adding it shortly.
Old Feb 5, 2025 | 03:09 PM
speakerfritz
I decided to go with the newest version FORD CCV
the thoughts I was wrestling with is the open question of lube value to turbo vanes or even upper intake that these crank case gas might have....and what little if any MPG plus it will give me.
I have an egr filter so Im not worried about egr clogging and I am running methanal/water injection so I am not worried about post inter cooler piping.
If my inter cooler winds up looking like a tar pit...I have a racor CCV 1 micron filter I can put on the ford CCV gizmo.
Old Feb 5, 2025 | 11:30 PM
kayakingpoodle's Avatar
kayakingpoodle
Can you please expound on both of these statements as I am very intrigued. The first one is of great curiosity to me. What vanes do you see getting lubrication from the ccv system?
Old Feb 6, 2025 | 11:33 AM
Ed in Maine
Something like this Fritz? seem to be around for under a hundred bucks or so.
Ford OEM Crankcase Filter, 2023-2024 6.7L Powerstroke (Upgrade For 2011-2022 Models)
SKU:FOR-PC3Z-6A785-A
Old Feb 6, 2025 | 12:39 PM
JoeUser's Avatar
JoeUser
I'm really not sure why they call them "filters", as the newest part has no filter media in it, and just allows vapor to pass through unfiltered. Or, am I mistaken (there's been so many revisions to this part I might've lost track)?
Old Feb 6, 2025 | 01:42 PM
speakerfritz
ponder items...
does the oil mist in the CCV gases lube turbo seals
does the oil mist in the CCV gases lube turbo VGT
is the oil mist in the CCV gases combustible....does that recover any lost MPG that is lost due to blow by
does the oil mist in the CCV gases carry off more turbo heat becuase the oil mist gases can hold more BTU's
does the oil mist in the CCV gases lube upper intake piston rings, valves, etc
everyone always talk about CCV gases bad things...but there might be some good things.
