2024 6.7 fuel filter part number
Fuel Water Separator Filter - Ford (HC3Z9N184F)
https://www.villagefordparts.com/v-2022-ford-f-350-super-duty--lariat--6-7l-v8-diesel/air-and-fuel-delivery--filtersI did it for 2020, 2022 and 2024...
But you're looking for Motorcraft set FD4625AA...
https://www.oreillyauto.com/detail/c.../mot0/fd4625aa
says it's good for 2017 to 2024.
Okay so on diesel filters online, this one here says that it relaces the above referenced part numbers...
https://www.dieselfiltersonline.com/...2-filters.html << $71.95
>>>>SKU: FD4641(LC3Z-9N184-A)<<<<
[FD4641/LC3Z-9N184-A]2017-UP Ford 6.7 liter Powerstroke turbo diesel Motorcraft fuel/water filter kit(2 filters). Says for 2017 through 2023 which would include your truck as well..
>>>>This now replaces the FD4624,Fd4625,FD4625AA<<<<
BUT, these will work as well... says for year 2017, but the filter system is the same for up to 2024. Maybe the filter specs changed??
https://www.dieselfiltersonline.com/...2-filters.html << $63.95
[FD4624/HC3Z-9N184-B]THESE ARE NOW >>FD4641<<
https://www.dieselfiltersonline.com/...es-fd4624.html << $72.95
says for 2017 to 2021...
[FD4625(HC3Z-9N184-C)]THESE ARE NOW >>FD4641<<
WOW... Autozone has the FD4641 set for cheaper... $69.99!!
https://www.autozone.com/filters-and...41/1103556_0_0
Here's from a review there...
Genuine OEM Motorctaft parts
3 days agoGenuine OEM Motorcraft part at a fraction of what the dealer charges. Nothing but the best! The only brand which meets Ford factory warranty compliance specs. Change these fuel filters EVERY 10K miles. * PRO TIP * Change when fuel tank is at 1/4 full to reduce pressure in fuel system & minimize chances of getting soaked in diesel.
What kind of vehicle do you drive?
2021 Ford F250 6.7 PowerStroke Diesel
went back on village ford parts and searched FD4641 and walla... $83.19
https://www.villagefordparts.com/oem...c=cT1GRC00NjQx
Fuel/Water Separator - Ford (PC3Z-9N184-C)
Hope this helps...
Hope this helps...
Good luck.
Just curious? Seems like the aftermarket filters are much bigger and better and easier to install and cheaper to buy new filters.
Thanks and good luck!
And fleets worldwide put BILLIONS of miles on metal filters every year, that S&S video has people thinking that their fuel systems will reduce to iron oxide if they have metal filters which is flat out not true if the end user performs even the most basic level of care.
Only time it's going to bypass is if the fuel gets gelled and in that case you WANT it to bypass until it warms up.
algae prone
thats how my engine bay filter burst
dont want crud going to the injectors due to filter by pass.
on 17 thru 19’s the engine shuts off when fuel pressure drops …cp4 doesn't run dry.
That was just an extreme case scenario which showed what can happen with consistent bad fuel use, to aftermarket fuel filters, but also showed the reliability of the new DCR pump.
