Sponsored by: Real Truck
1999 F350 V10 spark plug
Old Jun 22, 2024 | 08:57 PM
3Eagles's Avatar
3Eagles
5th Gear
Angry 1999 F350 V10 spark plug
I have a spark plug that is frozen into a thread insert in my V10. The plug and the coil both spin in the head making it difficult if not impossible to remove. Is there any possible way to remove this without removing the head from the engine?
Old Jun 24, 2024 | 08:24 PM
99f350sd's Avatar
99f350sd
Gee sounds tough. You may have to try to push down while turning the plug to get the insert to lock...other than that I don't see any way to remove it.
You may have to pull the head. The insert prob won't come out even if you have the plug in hand.
Old Jun 24, 2024 | 09:03 PM
'89F2urd's Avatar
'89F2urd
it depends on a few different things, mainly, what style of insert was used?
3Eagles's Avatar
3Eagles
5th Gear
Thanks I'll give it a try. The insert has definitely spun in the head so no threads left there.
Old Jun 24, 2024 | 09:14 PM
'89F2urd's Avatar
'89F2urd
Assuming it's the run of the mill spark plug spitter repair insert, the threads may not be damaged. Just unthread it, let it come out, and see what the head looks like
Old Jun 25, 2024 | 11:27 AM
3Eagles's Avatar
3Eagles
5th Gear
The problem is the insert is frozen onto the spark plug and the whole thing turns in the head. It appears the threads in the head are wiped and the plug wont turn out of the insert. No idea what repair was used as I can't get it out.
Old Jun 25, 2024 | 12:58 PM
'89F2urd's Avatar
'89F2urd
That's very strange, that the insert won't come out if it's spinning. Is it possible to post a pic?
The only thing I could think to try, would be to use a 1/4 inch impact to try to break the plug loose by utilizing whatever friction + inertia resistance the insert still has to offer. This would be done by putting the impact on the highest setting and squeezing the trigger rapidly for short, instant bursts in reverse
Old Jun 25, 2024 | 01:31 PM
3Eagles's Avatar
3Eagles
5th Gear
That is an interesting suggestion. I'll give it a try. My mechanic has tried a couple of ways to get it out but there appears to be a bit of thread or lip at the top of the hole that keeps the plug and insert from pulling out. Its possible it may eventually blow itself out but in the meantime I have a miss.
Patrick Coleman
Dec 23, 2022 07:26 PM
galaxieman390
Modular V8 (4.6L, 5.4L)
Dec 19, 2021 06:12 AM
zoey
Mar 24, 2007 12:27 PM
raazrbks
Jan 2, 2005 11:43 AM
yz450kid
Dec 19, 2004 09:04 AM
