Wheel bearing noise after replacement
Old Apr 10, 2024 | 09:13 PM
Anonymous12's Avatar
Anonymous12
I have an 88 f150 RWD. I replaced the front wheel bearings, with TIMKEN bearings and races. New seals as well. But now below 30 they squeal, above 45-50 they hum. My instructor did the preload on the passenger side that sides fine. The drivers side a classmate did the preload with my instructors supervision and me and that’s the side that has the noises. What should I do to fix it?
Old Apr 11, 2024 | 06:36 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Take apart both sides, clean, inspect, repack and reinstall.
Old Apr 11, 2024 | 10:37 AM
Anonymous12
Sorry, I wrote they both squeal and hum. It’s just the drivers side from what I can tell. With that being the case, do I still need to do both sides or just the drivers side?
Also there’s 2 different size dust caps on the part store websites. Is there something that I can look at on my truck with a factory option, to see the difference or is it just random sizes on random trucks?
Old Apr 11, 2024 | 11:34 AM
Hit Man X's Avatar
Hit Man X
Last set I did needed some specific torque procedure for fresh bearings, probably to initially load them. It was in the FSM, I do recall some high torque setting (125ftlbs?), then loosen. Then back to 20ftlbs and line up the castle nut. NOT exactly that data, but in that area. Worth checking the OE procedure.
Old Apr 11, 2024 | 07:34 PM
Soup bean's Avatar
Soup bean
From Haynes
Old Apr 12, 2024 | 04:43 AM
manicmechanic007's Avatar
manicmechanic007
Make sure the squeal or hum is not coming from the backing plate contacting the rotor
Old Apr 19, 2024 | 11:12 PM
Anonymous12
Backing plate and rotor are not contacting. Torqued bearing nut to 25 lb ft and backed off 1/8 turn just like the prodemand website said. No more humming. But there’s still a squeal, thinking pads? I’ll drive it again tomorrow to see if the squeak stops with brakes applied. No discoloration either.
Old Apr 20, 2024 | 05:32 AM
My4Fordtrucks
What did the bearings look like? Any metal in the grease?
Old Apr 20, 2024 | 08:50 AM
Ratsnesthd's Avatar
Ratsnesthd
I’m assuming you put in new seals cuz of they go in dry with no lube they have a tendency to squeal.
Old Apr 20, 2024 | 11:27 AM
Anonymous12
No metal, that I could tell. The grease is grey though. I didn’t replace seal this time. I put grease on the seal. Inner bearing looked good so I didn’t pull it out cause I didn’t have a new seal on hand.
Old Apr 20, 2024 | 12:35 PM
Ratsnesthd's Avatar
Ratsnesthd
well the inner bearing could be your problem. There’s no real way to prove that bearing is actually good unless you pull the seal wash out the bearing and inspect . Then to get all the old grease out of that bearing. Don’t go through all that work just not to remove the inner bearing cuz of a cheap seal that should be replaced anyways. Like doing half the job.
Old Apr 20, 2024 | 01:03 PM
Anonymous12
Seal and bearing are brand new and new grease is why I didn’t pull it.
I’ll diagnose the sound more, see if it stops when brakes are applied. If it does I’ll leave the bearings alone, if it doesn’t I’ll go get a new seal and repack inner bearing.
I replaced them for my auto class and drove 45 minutes home (not fwy driving) drove it maybe 1 mile for diag since.
Old Apr 20, 2024 | 03:10 PM
Anonymous12
The squealing changes when brakes are applied. Sound doesn’t go away though.
Old Apr 20, 2024 | 03:22 PM
R&RFord's Avatar
R&RFord
I had a high pitched noise when braking. Was still present after new pads and machining the rotor. New bearings took care of it. Came back a few years later. Got back into it and found the inner bearing was jacked up again. Found the race was loose. Hub was worn out. That was the core problem.
Old Apr 20, 2024 | 04:55 PM
Anonymous12
Do these look glazed? Also the pad backing plate had slipped out before i compressed the pads that’s fixed
The squeaking also only happens in drive. Not in reverse
