Differences between 2016 and 2017 F450 C&C
Old Mar 15, 2024 | 04:01 PM
Tuna!'s Avatar
Tuna!
6th Gear
I am looking at both a 2016 & 2017 F450.
It seems like Ford changed a fair bit starting 2017. Like the rear axle to the M300. Possibly the frame and updates to the 6.7l.
The 2016 already has a dump on it which I need. Better setup for me. But I’m really curious what I will be losing/gaining over the 2017.
Can anyone please help me?
I’m mostly concerned with frame, suspension and also engine.
I haul and tow a lot of weight
Old Mar 15, 2024 | 07:47 PM
HRTKD's Avatar
HRTKD
I can only tell you some of the differences between those years with the pickup version. Aluminum body, stronger frame, more HP/TQ., different interior and as you already know, the axle.
Old Mar 16, 2024 | 08:57 AM
speakerfritz's Avatar
speakerfritz
The differences might no be the same for C&C vs pickup
The cp4 has a change to produce slightly more psi. The co4 cam has a coating to slow down wear.
the engine is basically the same from 2016 thru 2019
the fuel pump was moved into the fuel tank in 2017. A return line was added to secondary fuel filter in engine bay.
starting 2017 the pcm monitors fuel pressure for a lift pump drop …if the drop is detected…the engine shuts off. Drops can be cuased by filter issues, line or filter burst, or in tank pump fail. Shutting the engine off immoderately helps protect the cp4 from running dry.
56panelford
21
Jan 1, 2022 08:58 AM
fisherman_chuck
23
Jun 25, 2015 05:48 PM
Volvo92906
Sep 1, 2010 09:12 PM
58cdn100
Jul 10, 2010 02:27 PM
57phil
Feb 21, 2008 11:26 AM
