Sponsored by: Real Truck
dana 60 front - srw vs drw differences? '99-'04
Old Mar 2, 2024 | 09:58 PM
Mitch Wood's Avatar
Mitch Wood
hey folks
Im looking around for a front dana 60 from a 99-04 pickup and they arent as easy to find as the 05+
Im wondering what the difference is between the drw and srw front dana 60s? there are a few around and im thinking they have less wear and tear as i would think drw trucks spend less time in 4wd.
i have read that the drw kingpin axles are the same but use a different hub. I am wondering what the differences are on the 99-04 axles which use balljoints and unit bearings
I need to find the axle for a 4x4 conversion on a van.
any help is appreciated
Mitch
Old Mar 4, 2024 | 07:51 AM
nydiver's Avatar
nydiver
Length wise I believe they are the same. You may need to change the unit bearing as the DRW studs may be shorter for just mounting the rotor and wheel adapter, just a guess, but the bolt pattern there is the same. Brakes are the same
Old Mar 4, 2024 | 10:02 AM
Mitch Wood's Avatar
Mitch Wood
thanks for the info. so the drw 4x4 just use a spacer between the unit bearing and rim?
Mitch
Old Mar 5, 2024 | 01:14 PM
redford's Avatar
redford
FTE Leadership Emeritus
Mitch
Correct.
My reply is too short so I must add more.
Old Mar 5, 2024 | 03:48 PM
Mitch Wood's Avatar
Mitch Wood
Originally Posted by redford
Correct.
Thank you for clearing that up.
Can you confirm that the dana 60 only came in 02-04 trucks?(between 99-04)
i cant use a 50.
Mitch
Old Mar 5, 2024 | 04:12 PM
nydiver's Avatar
nydiver
50 was 98-02 then it was gone, there was overlap so earlier than 02 is possible. Found this for you https://www.blueovaltrucks.com/tech-...50-vs-dana-60/ I believe the 229 vs 248 is found on the pass side of the cast support area, and its upside down if you were under the truck looking for it. The snout is a pretty good giveaway too.
Old Mar 5, 2024 | 07:58 PM
WE3ZS's Avatar
WE3ZS
i cant use a 50.
Mitch
Why can’t you use a Dana 50?
Old Mar 5, 2024 | 10:05 PM
Mitch Wood's Avatar
Mitch Wood
sorry let me rephrase that, I dont want a dana 50 under my 8000lb van
Mitch
Mitch Wood's Avatar
Mitch Wood
thanks a lot for your help
Old Mar 6, 2024 | 09:17 PM
Mitch Wood's Avatar
Mitch Wood
I think it should be possible to just replace the shorter DRW studs with longer ones.
looking at pictures on rockauto the studs can absolutely be pressed out without interfering with the unit bearing, although the axle housing could be in the way, Im not sure.
it looks like I will end up with a DRW axle, cant find anything else.
dorman wheel studs are $6
I'll update if I end up doing the swap
wahlturfcare
Dec 12, 2019 08:10 AM
TheTinian
Jul 17, 2008 06:38 PM
62uni4x4
Jun 7, 2004 01:57 AM
Hardcore4x4er
Mar 18, 2004 11:46 PM
Megalomaniac
May 19, 2003 01:54 PM
