Sponsored by: Real Truck
05 f250 5.4 lost its mind.
Old Mar 2, 2024 | 05:34 AM
The jeep guy's Avatar
The jeep guy
3rd Gear
I have an 05 f250 5.4 4x4. Truck will run fine and run well for a few minutes. After that truck will go into limp mode. Loses communication with all trans sensors and will stick the maf readings where they are at. Runs super rich wont shift. Key off key on truck is fine for a few minutes again. Will get codes from bad bank 1 knock sensor to bank 1 and 2 stuck lean. Also get the throttle correlation codes and sometimes a maf code. I have replaced the throttle body and tps. New maf sensor. Also installed a new ecu with was vin matched. Have good fuel pressure. No miss fires or anything. Will show high fuel trims from startup. Like 5 to 10 percent on lt and will bounce from 0 to 5 on st. When it freaks out it sticks the maf where it was and goes rich as heck. Will be fine if u key off and back on for a few minutes. I'm at a total loss with this. And I don't really know the history as I recently bought the truck. Thanks everyone for your time.
Jsheets0718
Feb 17, 2020 09:43 PM
ecolandscaping17
Dec 11, 2012 06:24 AM
Blue Jay
Modular V8 (4.6L, 5.4L)
Jul 24, 2012 08:38 PM
66fdtrucknut
13
Jun 17, 2009 03:57 AM
2000 E350
Jan 16, 2006 07:56 AM
