1953 F250 Parking Brake band
Old Jan 30, 2024 | 03:40 PM
Pops26's Avatar
Pops26
4wd Low
Hello
the F250 I am restoring has a badly damaged Brake Band on the parking brake. Any idea where I could find a replacement? even an aftermarket ?
Thanks
Pops26
Old Jan 30, 2024 | 05:19 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
You can see what your local heavy truck brake & clutch shop could offer. If the damage is confined to the friction material, they definitely should be able to reline it. Beyond that, it would be worthwhile to see what they could do for the band structure itself.
The band assembly (complete with friction material) is -2648. If yours can't be rebuilt/relined as suggested above, your next best bet would be to reach out to Chuck's Trucks LLC, give 'em a call and see if there is something serviceable in their inventory.
Old Jan 31, 2024 | 10:12 AM
Harrier's Avatar
Harrier
Pops, welcome to FTE!
We would love to see pictures of your truck.
Reading closer before I posted, this info below if it is just the brake material. If the metal band is bad I would agree that Chuck's Trucks should be your first stop.
Show us some pictures of your brake band.
I did it myself. Here is a thread on the topic.
https://www.ford-trucks.com/forums/1...l#post13977086
Here is info on the material I used.
https://www.ford-trucks.com/forums/1...l#post13890315
I used 2" by 3/16" lining material
Old Jan 31, 2024 | 11:17 AM
Pops26's Avatar
Pops26
4wd Low
Broken Brake Band PIC's
Hi Harrier & All
I removed it from the truck. late yesterday. Here are some shots, Terry's is checking his inventory too. I haven't heard of Chucks Trucks. (?)
I will be checking them out
Thanks
Pops26
Old Jan 31, 2024 | 11:23 AM
abe's Avatar
abe
The band doesn't look damaged to me.
Old Jan 31, 2024 | 11:52 AM
Pops26's Avatar
Pops26
4wd Low
One of the end pieces has completely broken off. I laid them together - I have another picture I will post of it broken. It actually looks like the band rubbed on the drive for so long it wore through the metal.
Old Jan 31, 2024 | 11:53 AM
Pops26's Avatar
Pops26
4wd Low
Old Jan 31, 2024 | 01:53 PM
52 Merc's Avatar
52 Merc
There's bound to be plenty of those bands out there. The same part was used from 51-56 on F2/250 and F3/350 trucks.
Old Jan 31, 2024 | 02:19 PM
56panelford's Avatar
56panelford
Where are you located..?
Old Jan 31, 2024 | 02:49 PM
Pops26's Avatar
Pops26
4wd Low
Lynchburg Virginia USA
Old Jan 31, 2024 | 02:51 PM
56panelford
That will likely help you if there is someone close
Old Jan 31, 2024 | 04:20 PM
Pops26's Avatar
Pops26
4wd Low
This is exactly like mine.
Thanks John.
Old Jan 31, 2024 | 05:15 PM
56panelford
If you can't find one close I could likely help you out, that is the 3 speed heavy duty transmission from my Mercury M350..
Old Feb 15, 2024 | 01:00 PM
Pops26's Avatar
Pops26
4wd Low
Another Brake Question
First found the Brake Band through Terry's in Nebraska- Now having it re-lined (not cheap)...
New question:
MASTER CYLINDER
Please look at the picture. there is a second port inside the chamber and I am not sure where is goes. I have cleaned thoroughly but not sure where it ports to, I cant get anything in there to see if its clogged?
Thanks
Pops
Cmac21
Jul 28, 2023 05:52 PM
hillbilly1989
Jan 18, 2018 11:03 AM
mattn03
Aug 20, 2017 05:38 AM
Pastor Scott
Feb 3, 2017 09:01 PM
Bob_91SC4x4
Dec 4, 2010 08:13 AM
