C6 to np235 swap
Old Jan 14, 2024 | 06:17 PM
Dr.Greasemonkey's Avatar
Dr.Greasemonkey
4wd High
C6 to np235 swap
Just want to check and see if I'm missing anything before I begin the swap. I have the transmission, I replaced its input shafts seal bearing and bearing race. I have : new rear main seal, new pilot bearing, new throughout bearing, new clutch, clutch save cylinder, clutch master cylinder, clutch line, trans to transfercase adapter, manual steering column, manual pedals, manual starter, manual 4x4 floor plate. Am i missing anything? I'm not sure if I need it, but I also have a manual cross member from a 2 wheel truck.
Old Jan 14, 2024 | 06:21 PM
Franklin2's Avatar
Franklin2
What is the transfer case adapter for?
Old Jan 14, 2024 | 06:53 PM
Dr.Greasemonkey
4wd High
It's for an np208, so i can use my existing tcase.
Old Jan 14, 2024 | 07:11 PM
Franklin2's Avatar
Franklin2
All Ford transfer cases have the same bolt pattern and shaft size and will bolt to all Ford 4x4 transmissions. No need for a adapter. If you happen to have a 2wd transmission, and are planning to bolt a 4x4 adapter on the back and then bolt it to your transfer case, that will not work.
Old Jan 14, 2024 | 08:35 PM
Dr.Greasemonkey
4wd High
The t18 t19 and np435 transmissions, have a tailshaft adapter that goes between the transmission and transfercase, to mount the tcase to the transmission. It's about 6 inches long and converts the trapezoidal flange on the transmission to the round flange on the transfercase.
Old Jan 14, 2024 | 08:52 PM
Franklin2's Avatar
Franklin2
If you have a 4x4 transmission, it should bolt right up to the transfer case. If you have a 4x4 transmission that is missing a piece, be careful, I have never heard of a separate piece flying around that needs to be sourced. If you have a 2wd transmission, forget it it, it will not bolt up no matter what adapter you have. You can convert a 2wd transmission to 4x4, but you have to tear the 2wd transmission completely down and install the correct parts, which among other things are a different output shaft and different housing on the tail.
Just tell me you have a 4x4 transmission and I will leave you alone.
Old Jan 15, 2024 | 01:02 AM
Dr.Greasemonkey
4wd High
I have a 4x4 transmission. This is what I'm referring to.
Old Jan 15, 2024 | 07:25 AM
Franklin2's Avatar
Franklin2
You didn't mention it, but it's pretty obvious. You have the bellhousing to fit your engine? The 4 speed has a separate bellhousing, and it can fit most all different Ford engines, but you must have the proper bell to bolt to your type of engine family. The bellhousing should also have mounting for your slave, depending on what engine you have. I believe most 300, 302's have a concentric slave/throw out bearing, while most 351w/460 and diesels have the external slave which needs the mount cast into the bellhousing.
You will re-use your transfer case shifter. Hopefully this transition piece you are talking about which normally comes with the transmission, has the threaded holes for your transfer case shifter. Just take a glance and see if it does.
Here are some pictures.
Old Jan 15, 2024 | 08:02 AM
FuzzFace2's Avatar
FuzzFace2
In short what DaveF is saying is the 4x2 and 4x4 transmissions have different output shafts and why you cant use a 4x2 on a 4x4 set up or the other way around.
This also goes for auto transmissions too, output shafts are different between 4x2 & 4x4 transmissions.
The only thing I did not see if the firewall reinforce plate for the master.
If you mount the master to the firewall like the factory did over time the firewall will crack and the clutch will not work as it should.
This plat spreads the load out farther and keep the firewall from cracking.
Dave ----
Old Jan 21, 2024 | 03:20 PM
Dr.Greasemonkey
4wd High
I'm proud to report there is now one more manual bullnose in the world.
Old Jan 22, 2024 | 02:16 PM
FuzzFace2's Avatar
FuzzFace2
Cool did you add the firewall plate as part of the install?
If not the firewall may crack down the road.
Dave ----
Old Jan 30, 2024 | 09:04 PM
Dr.Greasemonkey
4wd High
I wasn't able to find one locally, I'm on the lookout for one and plan to install one.
Old Jan 31, 2024 | 12:25 PM
FuzzFace2's Avatar
FuzzFace2
Check with Jeff's Bronco Grave Yard to see if he has them.
A FYI they came in 2 different sizes but think all you can get now is the smaller one?
Dave ----
Old Jan 31, 2024 | 01:57 PM
BigBlue2's Avatar
BigBlue2
Here's the link to the reinforcement plate with modifications for easy install
https://www.ford-trucks.com/forums/1...made-easy.html
frankiethethumper
1978 - 1996 Big Bronco
Jul 17, 2017 10:48 AM
ManfredVonRichtofen
Apr 25, 2014 06:53 PM
Peter Panos
1983 - 2012 Ranger & B-Series
Jan 21, 2013 04:16 PM
93Ranger
Jun 13, 2012 02:44 PM
weswes01
Oct 15, 2007 10:28 PM
