Automatic transmission leaking...oil pan?
Old Dec 17, 2023 | 12:33 PM
Lex2002's Avatar
Lex2002
Hey Gents,
This old truck...makes me crazy. Always something.
I put a rebuilt FORD trans in 2011 years ago...new from Ford. I dont drive the truck much...probably only has 40k miles on the trans. Thats part of the problem.
Its leaking I noticed today after a few long trips. Is it more than likely just the oil pan gasket?
I did the swap myself and if I recall it send trans fluid to the trans cooler but no red engine coolant runs through the trans so this couldn't red coolant, correct?
Old Dec 17, 2023 | 12:55 PM
RacinJasonWV's Avatar
RacinJasonWV
ATF is red.
There should be an oring on the dipstick tube. It kind of looks like it’s leaking from up there in this photo. I’d clean it all up and check again.
Old Dec 17, 2023 | 04:27 PM
Lex2002's Avatar
Lex2002
Thanks Jason. I had the dipstick tube out when I did my up pipes/turbo rebuild in February. O-ring looked ok.
Maybe that was its last hurrah...anyone have the specs on the replacement or do I need to bend the knee to Mr. and Mrs. Ford?
3 cent o-ring plus $15 shipping.
Thanks Jason! Note the truck is parked at an incline facing down towards the front so its gonna collect on the front.
Old Dec 18, 2023 | 04:02 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Talking
Thanks Jason! Note the truck is parked at an incline facing down towards the front so its gonna collect on the front.[/QUOTE]
Where I come from, we would say it was parked on a decline.
Old Dec 18, 2023 | 04:08 PM
Lex2002's Avatar
Lex2002
hahaha....so true!
me English no so good...
I ordered a Mr. Ford o-ring along withgo a few other parts I needed.
Old Jan 7, 2024 | 05:40 PM
Lex2002's Avatar
Lex2002
I went to change the O-ring for two "halves" of the dipstick tube and the short elbow that goes into the transmission body pulled out and and I got THE geyser of transmission fluid. My god man. I must have lost 3 quarts. (truck parked on slight decline)
The O-ring I bought from Diesel O-rings (https://dieselorings.com/products/19...ck-tube-o-ring) is only for the two halves of the tube, and he claims that no o-ring seals the short elbow that goes into the trans body? I find this hard to believe. How does it seal at the transmission?
Old Jan 7, 2024 | 06:22 PM
RacinJasonWV
I can’t remember. I expect @Mark Kovalsky can answer this one.
Old Jan 7, 2024 | 07:09 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I know a lot more about how it works than how it seals, but I think I remember an o-ring there. I'm not certain.
Old Jan 7, 2024 | 07:22 PM
Lex2002's Avatar
Lex2002
Thanks Mark.
Mr. Diesel O-rings states that there is no ring there but wow I find that impossible to believe.
Old Jan 7, 2024 | 08:29 PM
Mark Kovalsky
I found an exploded view of the trans. It shows an o-ring between the two tubes, but none where the tube enters the transmission.
Old Jan 8, 2024 | 05:11 AM
John in OkieLand's Avatar
John in OkieLand
hello JB Weld steel.
clean it really good first, no grease residue
Old Jan 8, 2024 | 05:27 AM
charlie g's Avatar
charlie g
FTE Community Team
is there not a auto trans shop near you ?
Old Jan 8, 2024 | 07:46 AM
Lex2002's Avatar
Lex2002
Thanks so much! I'll raise the front end so the fluid moves backwards and pull the tube, clean and put back on and put on the new o ring at the halves of the tube.
When the truck is parked on even a sight decline the fluid moves far up into the dipstick tube. It's no wonder that o ring is so important.
Old Jan 8, 2024 | 07:47 AM
Lex2002's Avatar
Lex2002
Good idea!
Old Jan 11, 2024 | 08:03 PM
Lex2002's Avatar
Lex2002
Its sexy time guys...some old and slightly dry JBWeld Steelstick and JBWeld regular runny 2 part (yes this stuff does have a shelf life...and miine was pretty dry) and a new o-ring.
Go get your popcorn...
And the short eblow
Used some JBWeld around the dipstick tube to elbow connection as well but I dont think its gonna stay on as it wasnt stickling very well even though I cleaned and sanded all the surfaces.
