5.0L Coyote 5.0l Ford OHC Coyote engine for 2011+
2015 5.0 coyote cold drive tick/knock
Old Sep 18, 2023 | 01:47 PM
Huffmjo2's Avatar
Huffmjo2
1st Gear
Motor is knock/ticking clearest between 1500 and 2 RPM’s through all gears…. After driving a bit it clears up. Where should I start? Also what is the heaviest weight oil that you all recommend to use in these motors?
Old Sep 27, 2023 | 12:46 PM
xlt4wd90's Avatar
xlt4wd90
The variable valve timing system depends on specific oil viscosity range to function properly, so it's not a good idea to use oils with viscosity that are too far from recommended.
Old Nov 13, 2023 | 07:31 AM
craftsmangary's Avatar
craftsmangary
Those "ticks" from the valve train area is usually a failing roller bearing on a rocker arm or roller lifter on non OHC engines. The long you wait to fix it the more it will cost.
Melonmuziq
21
Oct 16, 2019 04:21 PM
jvaski
1997 - 2003 F150
Dec 8, 2012 09:52 AM
Firminator_X
1997 - 2003 F150
Jan 15, 2010 11:44 AM
4x4 Bart
Apr 26, 2009 03:05 PM
lumprsmith
Jan 3, 2004 06:01 PM
