Transfer case drop after caster shim installation?
Old Aug 13, 2023 | 08:51 AM
Tbug05LTD's Avatar
Tbug05LTD
Hello all. It's been a while since I've been on here and since that time I have installed 2 degree WFO caster shims (correctly with thicker portion to rear) and it seems to have helped with some of the wander. I don't remember the before and after alignment readings so I'm taking the ex in for an alignment in a couple weeks to see where caster is at. If it is around 4 degrees positive caster on each side I'm thinking of redoing with 4 degree shims. Has anyone used the 4 degree shims and found the need to drop the t-case to compensate for the change in axle pinion angle to the front driveshaft? I know this is only an issue when in 4wd but if it will be a concern of vibrational noise or significant increased u-joint wear I would like to address at the time of the caster wedge installation. Thanks.
Old Aug 13, 2023 | 09:43 AM
pirate4x4_camo's Avatar
pirate4x4_camo
Depends, How are you planning to drop the Transfer case ?
with 2* shims you should have at least 5*
if you still have wander you a pretty serious issue with a worn out component, I’d be inclined to fix that before going down the rabbit hole of altering the powertrain mounts.
but yes, i have moved the engine, transmission and Tcase lower, higher, back, rotated it and just about every combination of those to achieve some desired result.
also, Yes I have run more than 5* of caster. Have experimented with up to 10* and as low as 0*
Old Aug 14, 2023 | 12:10 PM
Antonm23's Avatar
Antonm23
If you're having front driveshaft vibration or joint binding issues, why not look into having a double cardan joint front shaft made.
To clock the transfer case any significant amount, you'd need to modify the transmission cross member to clear the front driveshaft at the transfer case end. A double cardan front shaft would require less modifications to the vehicle itself.
Are you having any issues or is this a theoretical question ?
Old Aug 14, 2023 | 08:53 PM
Tbug05LTD's Avatar
Tbug05LTD
All purely theoretical at this point. Once I get the alignment data in a couple weeks I can go from there. Thanks all for the input.
Old Aug 14, 2023 | 10:50 PM
pirate4x4_camo
A good shop will inspect everything that can effect alignment and not align it until any worn parts are out of spec since a worn part changes the alignment.
note I said good shop. Unfortunately most just set the toe and collect the dough.
anyhow, Post up your before and after specs.
Matthew78
Jan 21, 2020 11:18 PM
TFagerholm
Oct 20, 2011 10:27 PM
4x4bigblock
Feb 27, 2006 02:49 PM
GeneStoner
Mar 17, 2005 10:53 AM
TEEJAY
1997 - 2003 F150
Sep 9, 2003 08:38 PM
