Best radiator hoses
Old Jul 28, 2023 | 02:31 PM
Grampa69's Avatar
Grampa69
Best radiator hoses
I will be replacing my radiator hoses soon. In the olden days, I used Continental hoses. Is that what you recommend or is there a better one? I don't want shiny colored hoses, just prebent black rubber hoses. So what's best?
Old Jul 30, 2023 | 07:28 PM
Beechkid's Avatar
Beechkid
I'm a Goodyear Guy! (
Old Aug 15, 2023 | 01:55 PM
Grampa69's Avatar
Grampa69
Well. I guess one is as good as another.
I bought Napa hoses. Looking at the cast iron water pump connection and the lower hose connection, l know the old hoses will likely have to be cut and scraped off. In your opinion, should I sand/file or prep the cast locations before fitting the new hoses on? I've never used sealant one hose connections before but read online about using rtv or silicone? Opinions? Here's what 60 years did:
Old Aug 15, 2023 | 02:07 PM
Grampa69's Avatar
Grampa69
Here are clearer pictures of the hose ends flared.
also, should the clamps be bare metal, shiny or ? That is if they survive being removed.
Old Aug 16, 2023 | 02:49 PM
Beechkid's Avatar
Beechkid
IMHO, I would avoid Gates belts/hoses unless you are planning on selling the vehicle within a few years..... they are short term life belts/hoses as compared to other mfgs such as MC, Goodyear, AC Delco, etc. With regards to cleaning the fittings, I use and would recommend a wire brush attachment on a drill.....not the real stiff wire wheels but the softer ones and they will clean that up nicely.
Old Aug 17, 2023 | 08:58 AM
Grampa69's Avatar
Grampa69
I went with Napa brand (not sure who makes them). I am also ordering clamps. They are stainless and 3/4" wide. They look like the ones on it but with a different bolt. At $8.50 each, I hope they are good.
NAPA part # BK 7051531
Old Aug 17, 2023 | 02:10 PM
Grampa69's Avatar
Grampa69
ok well.. gates makes the hoses for napa.
The clamps were the wrong size. I drove around til I got ss clamps that fit but no t-bolt or original style. After I change hoses and clamps, I will see if the old clamps are salvageable.
Old Aug 25, 2023 | 06:00 PM
abe's Avatar
abe
Carpenter and others sell period correct hose clamps. They make a difference in the appearance of your stock truck.
Old Aug 26, 2023 | 06:42 AM
Grampa69's Avatar
Grampa69
I was lucky so far. I replaced the upper hose using the old clamps.
SoCalSuperDuty03
Dec 28, 2011 08:52 PM
rsylvstr
Jan 18, 2007 08:19 AM
rmalottwtes30
May 14, 2005 02:00 PM
AMW
Dec 21, 2004 06:57 PM
