77 f250 hazards.
all new wiring, new light sockets, new lights, new fuse block and new turn signal switch. All the lights work even the turn signals as well as the hazard flashers when I pull the ****. I am at a loss as to why.
D1FZ-13350-A .. 4 Way Emergency Flasher - Heavy Duty (Motorcraft SF-552-B) / Available from auto parts stores.
The 4 way flasher can also be used with the turn signals, but the turn signal flasher should not be used with the 4 ways, as it's a "weak sister."
The T/S flasher plugs into the back of the instrument cluster at upper left.
The 4 way flasher fits into a U shaped bracket that is retained to the back of the dash (adjacent to instrument cluster) w/a screw.
when I pop the hazard ****, the hazards work as intended, (all four corners flash) when I trip the turn signal, each direction works as expected (front and rear each direction, flash) and the rear two blinking lights stop while a direction is tripped. When I turn off the blinker, the two rear lights go back to blinking. This is without a key even in the ignition.
Like it sounds like yours is doing.
Only the turn signal circuit needs the key to be turned to ON or ACC.
Same for the brake lights.
When your hazards are flashing and you push on the brakes on these old vehicles, the hazards stop flashing. So it sounds like all that is working as expected other than the hazards in the rear being on all the time.
This is kind of an odd one that I don’t think I’ve ever heard of. Only thing that comes to mind at first is a defective hazard switch.
I’m guessing the 77 has the same integrated hazard with the turn signal switch, as the later models do. Or is there a separate hazard switch on the dash like some earlier models might have had?
i rewired the truck completely with the kwik wire harness. Everything is new. I have since switched a couple wires from the column which fixed the rear hazards going off but now, none of the turn signals work. Even with new heavy duty flashers.
If you have a known good flasher, such as the one for the hazards that are currently working, swap it with the other flasher to make sure that the flasher itself is not the issue with the turn signals.
It’s an epidemic of faulty parts now. So putting new parts in a vehicle literally just adds more potential culprits when trying to track down an issue.
When you installed the new harness, did you also renew old and add new grounds?
From the battery, you should have the main ground to the engine block (of course) AND a secondary ground to the body somewhere nearby. One of the bolts to the starter relay/solenoid is often a convenient spot.
Then you should also have a ground strap or wire between the back of the engine and the firewall.
Sometimes on older trucks that have seen lots of surface rust over the years and maybe even new paint jobs, you should add one from the battery (or body ground point) to the core support to brighten up the headlights.
Sounds like the lights themselves are grounded because at one point or another they all worked. So that’s a good sign.
You might call Kwikwire to see if they have any suggestions.
Okay, so I’m going to blame this on chemo brain because I already knew this AND read the answer above so maybe I’m just crazy.
I tested the new switch and it seems to be okay. I also used a power probe to make sure all the lights worked individually. I can not for the life of me figure out how I may have crossed a wire but it’s obviously possible with the way I’ve been working lately. It’s also possible that the wiring diagram kwik wire provides isn’t correct. I do have one big one from classic car wiring and aside from some colors being incorrect (neither the kwikwire or classic diagram are matching the original color codes in the old turn signal switch) everything else seems to match the old wiring I took out.
either way, I appreciate the help. I’ll get back into it tomorrow.
thanks
Which have pretty much become generic in the aftermarket industry.
Some manufacturers do have the option of Ford colors, but not many. So very likely your mismatched colors follow some general motors wiring scheme.
Unfortunately, it’s all too common, especially in the Bronco world, for the wiring diagrams to only match some years of turn signal switches.
Seems like that was a big change area especially around 73, 74 and 75.
I’ve pulled apart steering columns for six different 73 broncos and Only two of them matched. All the others were distinctly different. To the point that I started making cheat sheets, and instead of just writing the colors down, cutting the ends off the wires, and taping them to a piece of paper with a description of what they did.
I haven’t run across it as often on the full-size trucks, so I have no idea if the changes were as extensive.
And the ones in the Broncos I was dealing with were as far as I could tell were original factory switches.
The aftermarket is crazy with wiring color mistakes.
At least for turn signal switches go that is.
