My fuel pressure has consistently tested low at idle and during power breaking. I'm getting between 26-28 PSI on both the front and rear tank at idle. With the FPR vacuum hose disconnected I'm at 30 PSI. Testing while power breaking jumps to 34-36 PSI. I've never noticed a drop in fuel pressure with any of the tests, just lower than what I have seen listed as acceptable ranges.
Do these readings seem too low? Are there other tests to run that would narrow down the source of low pressure to the pump, delivery module, fuel selector valve, etc? I'm having a stalling issue under very low throttle and I'm wondering if it is possibly due to low fuel pressure.
I'm going to have the bed off the truck this weekend to inspect the fuel system more thoroughly so if I do need to replace parts, now would be the time to do it I guess.
Current KOEO codes are: (PO removed all smog/emissions components, blocked off egr, removed CANP, removed TAB/TAD, etc which I believe explain the codes)
334 - EGR closed voltage higher than expected
553 - TAB/TAD failure
552 - TAB/TAD failure
565 - Purge Valve failure
558 - Failure in the EGR Vacuum Regulator (EVR) solenoid circuit
Reason: Specifying Truck Year and Engine
Are you sure your fuel pressure gauge is accurate? Maybe try another gauge and see if they're roughly the same. Your "FPR vacuum disconnected" and your power braking measurements should be the same. What's you're idling battery voltage at?
Weak fuel pumps won't cause a stalling problem at low power settings.
Stumbling or stalling at low rpm could be a vacuum leak, TPS, ECT, or a few other things that others will suggest.
I have tested with two separate gauges and the results were within a couple PSI of each other. I've never seen above 30 PSI with either of them. Even if the lower pressure isn't causing the stalling, do these numbers seem low enough to be of concern?
What year is your truck and what engine does it have? Anything '90 or newer doesn't have a tank selector valve.
Yes those pressures are low, with vacuum removed from the regulator you should have 40psi min(V8's) or 55psi(I6).
Is this a dual tank truck? If so do they both work?
94 f150 351W 5.8L V8 E4OD. It is a dual tank truck and both tanks work. Good to know about the selector valve - I saw some other posts referencing it but must have missed the year.
The fact that your fuel pressure doesn't dip when power braking means that your pumps are fine. All signs point to a weak fuel pressure regulator or bad fuel pressure gauges.
I will say that with the original FPR - I was getting the same readings as the current replacement FPR. Guess it could be a gauge problem.. first test was done with a standard pressure gauge from amazon. I ended up installing a mechanical gauge directly on the fuel rail so I could keep tabs on it frequently and in different situations.
The big auto parts stores loan out fuel pressure testers for free with a deposit.
Not that I can tell. The fuel gauge appears to work on both tanks and they seem to hold true based on fuel consumption by tank. I can take both tanks down to E with the other staying full. Are there other indicators that fuel would be transferring between tanks?
But does the empty tank remain empty after switching to the other tank?
The common fuel transfer problem will overfill a full tank pushing fuel out the filler neck onto the ground, and there is no indication that is happening except perhaps a raw fuel smell after stopping.
Half of the fuel volume the pump moves just goes into the other tank unrestricted so the pump won't be able to build correct pressure at the engine. It's as if there was a giant leak in the fuel line.
