'78 F150 RCSB 4 spd Big block build thread!
Old May 1, 2023 | 09:41 PM
hivoltj's Avatar
hivoltj
Allright boys. I got a wild hair up my you know what to drop this 500(disclaimer actual HP may not be 500 but will be close to and a **** ton of torque) hersepower big block I've been building into this dentside.
Changed to a build thread, we doin this!
Which is/was my high school sweetheart that i re acquired.
Truck is currently a 400 and NP435.
It looks like Jeff's Bronco graveyard for the HD motor mounts, PS and alt brackets and possibly pullies?
What about mounting up to the Ole 4 speed? I know bell pattern is the same but possibly the 460 flywheel doesn't fit? I have a '79 and later flywheel already, engine is still external balance.
What flywheel, clutch (500 herse rated remember) and starter do i need?
I see some use a 390 flywheel and starter? I dont the balance be right for that.
HELP!
Old May 1, 2023 | 09:55 PM
5speed65's Avatar
5speed65
I tried the hd motor mounts on my 460 that has l&l stands and the angles were not lining up now with the factory 400 stands it might be different
Previous owner used a 351m bell housing and removed a ton of material to fit a 12in clutch
l&l should have a flywheel and clutch kit that will work for you
Old May 1, 2023 | 10:19 PM
hivoltj's Avatar
hivoltj
I have heard the L&L mounts get ripped up like stock ones do. I do have the stock perches. I had wondered if a guy could grind out the bellhousing but that combined with 500+ lb feet of torque probably equals snapped bell housing.
I do see that JBG sells a flywheel and clutch but no mention of HP rating, it's expensive and a 6 week lead time that I dont have.
Old May 1, 2023 | 10:37 PM
85e150's Avatar
85e150
Use a C6 and save yourself a ton of trouble.
Swerving suggestion.......
Old May 1, 2023 | 11:32 PM
5speed65's Avatar
5speed65
Or a zf5 from a later model truck
Old May 2, 2023 | 07:23 AM
79calicruiser's Avatar
79calicruiser
Got a 79 bronco with a 351m and np435 starting to consider engine and trans swap. 460 c6 looks like the ticket. Following your build help me decide and how to do it
Old May 2, 2023 | 08:43 AM
beardedcap's Avatar
beardedcap
If I were doing this, with a 460 having so many more later model trans options than an FE for example, I would get a 5 speed.
Old May 2, 2023 | 03:39 PM
Henson's Avatar
Henson
2nd Gear
I used a flywheel for an 84 F250 with a 460 when I did my swap. Clutch is an 11 inch. I don't know if a 12 inch will fit or not. I had to grind down 4 places on the inside of the bell housing so that the flywheel didn't rub, and I also had to take just a tad off the hub of the clutch disc because it was binding on the bearing retainer. I'm using a gear reduction starter from a 1996 F250 with 460. I spent months researching all of this before I did it
Old May 2, 2023 | 03:42 PM
hivoltj's Avatar
hivoltj
Fellers maybe if this truck didn't have so much sentimental value I'd consider it. The 435 stays (has a built c6 in the shop too).
This was my high school dream truck that I owned for many many and missed the opportunity to buy it back once. I had a second (or third depending on how you look at it) chance, scooped it up and here
we are.
I'd have **** myself to have a built 460 in high school. Probably would have killed myself too.
I will probably be going with the L&L clutch setup and possibly their mid length headers and JBG motor mounts.
Does anyway know what L&L HD clutch is rated for?
Old May 2, 2023 | 03:44 PM
Woodscustom's Avatar
Woodscustom
I used the L&L 400 to 460 swap kit. It worked great.
This 460 is mated to a NP435. I used the L&L HD Clutch too. The flywheel (50 lbs) bolted right up. Make sure you order the correct one for the Internal or externally balanced 460.
I do wish this truck had a 5 speed.
WC
Old May 2, 2023 | 07:18 PM
5speed65's Avatar
5speed65
L&l clutch can handle 560hp
Old May 2, 2023 | 08:49 PM
hivoltj's Avatar
hivoltj
WC
How much HP? And how are the headers?
Old May 3, 2023 | 02:15 AM
hivoltj's Avatar
hivoltj
Guys I found a youtube video on how to change the oil pan gasket does this seem right? Seems like a ton of work
Old May 3, 2023 | 02:24 AM
hivoltj's Avatar
hivoltj
I am calling L&L tomorra and getting parts on the way. You guys want me to see if I can get a discount code for forum members or subscribers to my YouTube channel? Be nice to get everybody 15-20% off.
Let me know! Also are the l&l mounts worth it or get the HD ones from JBG?
Old May 3, 2023 | 06:46 AM
somethingclever's Avatar
somethingclever
there is enough bad press out there regarding the L&L engine isolators that I would stay clear.
