C6 to T18 Swap
Old Apr 26, 2023 | 12:49 PM
coreyhall49's Avatar
coreyhall49
5th Gear
C6 to T18 Swap
I've never done a transmission swap before but I am tired of putting c6's in my truck. Looking for parts i'd need and a couple of things stumped me, I cannot find a flywheel for the 351m. from what i've heard the 351/400 use a 180 tooth flywheel, however the 180 teeth flywheels I have found are all marketed for the 460, will the 460 flywheel work? Also, my truck is a Lwb I believe 117" will the same driveshaft for the c6 work for the T18? looking around ive only found 1 driveshaft for the 2wd 117" wb trucks which leads me to believe they are at least the same length right?
Old Apr 26, 2023 | 01:01 PM
coreyhall49
5th Gear
Originally Posted by coreyhall49
Also, my truck is a Lwb I believe 117" will the same driveshaft for the c6 work for the T18? looking around ive only found 1 driveshaft for the 2wd 117”?
It is actually 133” after a quick measurement so I don’t believe they’ll be the same shaft
Old Apr 26, 2023 | 05:54 PM
john jamieson's Avatar
john jamieson
Depending on the year and application, Manual transmissions can have different output shaft lengths. I have an early T18 in my '64 and it is short. A t18 that came with a '93 300, 6 cyl , I bought), has a longer output shaft and no mechanical speedometer output.
Old Apr 27, 2023 | 08:09 PM
Rubiranch's Avatar
Rubiranch
I friend told me this morning at breakfast he just traded one of his trucks, a '70 F-150 with a 302
for a '76 highboy with a 4-speed and he's going to convert it to an auto trans.
Too bad you're not neighbors.
Old Apr 29, 2023 | 08:39 AM
speedfreak78's Avatar
speedfreak78
How many C6's have you gone through?? They are a pretty stout trannys. Even a slightly modified 351M/400 shouldn't hurt one in good condition and they can, relatively cheaply, be built to handle big HP/TQ.
bgblkdually
Apr 15, 2013 11:33 PM
fslay
Oct 23, 2010 08:55 AM
The Freak
Sep 25, 2009 11:50 AM
TBirdGuy
Jul 24, 2001 06:38 PM
