Shift points on 88 F250
Old Apr 19, 2023 | 06:29 AM
TheOldMansTruck's Avatar
TheOldMansTruck
4wd Low
Just curious... Anyone know what the normal shift points are on an 88 F-250 with the 7.5l automatic?
Old Apr 19, 2023 | 06:47 AM
R&RFord's Avatar
R&RFord
It is variable, depending on engine load and rpm.
You should have a C6 assuming it is stock. This transmission uses a vacuum modulator to adapt to engine load. If the vacuum signal is weak, not present or the modulator is damaged you will have late hard shifts.
The modulator can also be adjusted to alter the shift schedule to a small degree.
Steven Valvana
Jun 10, 2016 04:03 AM
Luckie117
Apr 30, 2005 07:06 PM
tcinks
Oct 5, 2003 02:02 PM
Dean Christensen
Aug 5, 1999 06:19 AM
