What ATF to use on '95 F150 E4OD?
Old Apr 18, 2023 | 03:02 PM
machgirl03's Avatar
machgirl03
I am getting so much conflicting information on what ATF to use on my '95 E4OD transmission. I am doing a filter/fluid change and I have the filter, but WHAT type of ATF do I use? Mercon is not made anymore and Mercon V is the most updated version of it...
Old Apr 18, 2023 | 03:10 PM
sandymane's Avatar
sandymane
Mercon V is what Ford now recommends. The Mercon LV is NOT to be used. I just changed mine and used Mercon V and put in a new cork gasket and new filter. All good.
Old Apr 18, 2023 | 03:17 PM
machgirl03's Avatar
machgirl03
OK. TY for the info. I have been over on so many sites searching for the correct answer but not getting anywhere. Is there any specific brand etc to use or not? Would synthetic be good or not? I have no idea if the trans in my truck has ever been serviced...I am just getting fluids etc changed after it was recovered back in January from being stolen. I had only had it less than 3 weeks before it was stolen and hadn't had the chance to do any servicing to it.
Should I flush the trans cooler or not? I am not really confident about flushing such an old system if it isn't necessary...
Old Apr 18, 2023 | 03:24 PM
sandymane's Avatar
sandymane
Re: the brand. Any of the Name Brand synthetics of MerconV should serve you just fine. The trans holds about 18 quarts if you drain the whole system. I only change the pan about 6 quarts total. When you change the filter the orange gasket on the filter may be left in the hole when you remove it. Mine was. Just make sure. If you want to change the entire system of 18 quarts there is a procedure for doing it.
Here is a video on how to do the whole thing.
https://www.google.com/search?q=how+...client=gws-wiz
Old Apr 18, 2023 | 03:41 PM
machgirl03's Avatar
machgirl03
It's ok to use synthetic ATF in these older transmissions? Esp with ones over 200k on them?
Old Apr 18, 2023 | 03:47 PM
sandymane's Avatar
sandymane
Yes but if you find MerconV High Mileage transmission fluid and you feel more comfortable using it you should be fine.
Old Apr 18, 2023 | 03:49 PM
sandymane's Avatar
sandymane
Changing fluid and flushing the E4OD completely does nothing to hurt the transmission. May have been so (in the day) but not now with synthetic.
Old Apr 18, 2023 | 04:39 PM
rla2005's Avatar
rla2005
If you are going change the trans fluid do a complete flush and refill. Just draining the pan is false economics on these old trucks IMHO.
Mark Kovalsky has a procedure on this forum buried somewhere.
Old Apr 18, 2023 | 05:23 PM
tjc transport's Avatar
tjc transport
i ain't rite
i would not use synthetic. regular mercon V is fine.
Old Apr 18, 2023 | 06:36 PM
machgirl03's Avatar
machgirl03
Yeah, I got the procedure. I will be doing what Mark did, to make sure all the old fluid is out.
Old Apr 18, 2023 | 06:39 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Synthetic is better, but if you're not working the trans hard it probably isn't worth the extra cost.
Use a fluid that says MERCONV on the front. Don't use one that says it can be used where MERCON V is required. The latter doesn't have a license and may or may not meet the MERCON V spec.
Old Apr 18, 2023 | 06:41 PM
machgirl03's Avatar
machgirl03
I am just gonna buy Mercon V from Ford. I found it on Amazon.
Old Apr 18, 2023 | 07:19 PM
rla2005's Avatar
rla2005
Good choice.
Old Apr 18, 2023 | 08:28 PM
torq'ta 5 8's Avatar
torq'ta 5 8
Did you notice Marks signature, guess who he, is.
Old Apr 18, 2023 | 08:57 PM
machgirl03's Avatar
machgirl03
Oh crap, no, I sure didn't! Good to know!
