1989 f250 460 no power to fuel pumps
Old Apr 16, 2023 | 03:26 PM
Redtruck96's Avatar
Redtruck96
4wd Low
Recently bought this ford in hopes to get it running but no luck. So far I have power to fuel pump relay, EEC relay. The pigtail going to inertia switch has nothing and neither does the selector switch. I get power to selector switch when I use a jumper wire on inertia switch but still nothing to pumps. Haven't checked computer yet and I haven't noticed any burnt wires but I'm lost.
Old Apr 16, 2023 | 05:01 PM
Prototypemech's Avatar
Prototypemech
First thing to do is check for engine codes.
when your turn the key to 'run', do you hear the fuel pump relay click once for 2 seconds and then click again? If so, then your ECU is fine.
Remove the connector from the inertia switch and check the internal resistance of the switch with a multi meter. It should be less than 5 ohms.
You can force the fuel pump relay on by jumping the EEC test connector fuel-pump terminal to ground as seen here. This will keep the fuel pump on anytime the ignition switch is in the 'run' position. This will help you diagnose where the power is stopping.
Old Apr 16, 2023 | 07:22 PM
rla2005's Avatar
rla2005
1989 F-Series gas engine truck dual tank fuel system diagram.
Old Apr 19, 2023 | 04:34 PM
Redtruck96's Avatar
Redtruck96
4wd Low
tried jumping as shown. Relays Engage but still no start.
MIKE861943
Sep 12, 2017 08:51 AM
bigwillisF150
Oct 12, 2015 04:37 PM
Tbrooks09
Apr 17, 2014 07:41 AM
binzer
Jul 19, 2012 11:37 PM
Ty_Yota
Apr 5, 2006 12:43 PM
