Fuel Pump Dilemma
Old Nov 17, 2003 | 09:20 AM
jellybellyjean's Avatar
jellybellyjean
Question Fuel Pump Dilemma
My truck has been running great until . . . . . . . .
We went to the movies Saturday and just before we got there we went to Taco Bell and the truck started and then died and did that twice. Gave it some gas and it stayed running. After the movies we came out and it would not start. It turns over but I cannot hear the fuel pump engaging. So it appears that my truck is suddenly not getting any fuel to allow it to start.
I have a 1992 F-150 (302) Supercab Flareside with duel tanks. I have heard that the fuel pumps in both tanks work together? I just don't understand what would make it suddenly not run. I went out and bought a fuel pump relay and replaced that and it didn't change things. I checked all the fuses and they seem to be ok.
Any ideas???
Old Nov 17, 2003 | 12:31 PM
mattydiesel's Avatar
mattydiesel
i would first check to make sure that you got the correct relay
i believe the fuel pump relay is green
next i would check the inertia switch, i believe in that year it is mounted either on the right side kick panel or on the firewall inside by the gas pedal
Old Nov 17, 2003 | 02:59 PM
andym's Avatar
andym
Only one pump at a time runs. It depends on the selector switch. If you flip it to the other tank (assuming they both worked before) and you get the same behavior, you can rule out the fuel pump as the cause.
If you can't hear the pump running when you first turn the key, then you have a wiring problem, a broken PCM, a tripped inertia switch, or a broken relay.
Old Nov 17, 2003 | 08:28 PM
jellybellyjean
Thanks for the replies. Of course at this time, I cannot find my manual. Anyone have a picture of the wiring for the fuel pump? Both switches for the two tanks have always work. I change tanks each time I run one out. When I flip both I still don't hear a sound from the fuel pump. Next I am going to check the wiring. Just seems weird that it just happended so suddenly.
Old Nov 18, 2003 | 12:40 AM
andym's Avatar
andym
Electrical problems are like that. Check a Chiltons or Haynes manual for wiring diagrams.
Old Nov 18, 2003 | 09:17 AM
jellybellyjean
Found the manual, now were in business!!!!
dyhrdford
40
Jul 17, 2011 07:02 PM
Talyn
22
Jan 29, 2010 08:59 PM
Scriv
Nov 4, 2009 04:44 PM
Beast12
1997 - 2003 F150
19
Dec 4, 2007 11:47 PM
apowder97
1997 - 2003 F150
Oct 13, 2006 08:50 PM
