22.5 swap from 9.0020's
What year is your F-600? The 1963 and 1964 F-600s, as well as B/C/N Series trucks, had hub piloted mountings. On them you’d need to switch to standard Budd right hand thread stud piloted fasteners on both sides of the truck if you are swapping to stud piloted tubeless 22.5s. Otherwise, if you now have a stud piloted mounting, the stock nuts will work on stud piloted 22.5s. I’m parsing my words here a bit because there were hub piloted 22.5s, but rarely do we hear of them. Stu
The following users liked this post:
If you have duals on the rear , you should have inner thimbles that go on with the first tire, then the lug nuts with the second tire. The thimbles will be stamped with an L or an R, depending on the side. Takes a special square socket to get them off and they break easily. Don't ask how I know, lol
vaden66
02-14-2012 08:18 PM
