Jack and jack stand points for 53-56 Ford Truck
Old Jan 28, 2023 | 07:50 PM
53FordTough's Avatar
53FordTough
7th Gear
I want to make sure I jack up my old 53 Ford truck properly as well as place the jack stands in the right location. Does anyone have a good description, pics, or video. I’m guessing in the rear, I jack up right on the center of the “pumpkin” or rear diff? Thank you so much for any feedback.
Old Jan 29, 2023 | 02:02 AM
1949f1's Avatar
1949f1
When I jack up my 49 in the front I put the jack in the center of the straight axle and put the stands near the king pins. On the rear put it in the center of the rear end and jack stands near the shock mounts, Give the truck a good shake to make sure it is stable and start the work.
Old Jan 29, 2023 | 06:56 AM
M2HB's Avatar
M2HB
I bought two pair of those plastic ramps. I just drive up on them with any low vehicle and back them up with jack stands. I like the ramps because they can be stacked for storage.
Old Jan 29, 2023 | 07:51 AM
51fred's Avatar
51fred
I do the same as Tracy, unless I need to drop the oil pan. Then I put the stands under the frame just behind the front axle so the front suspension can drop out of the way.
Old Jan 29, 2023 | 08:50 AM
53FordTough
7th Gear
Thanks for the awesome replies and info. Much appreciated!
Old Jan 29, 2023 | 12:36 PM
turnrjr's Avatar
turnrjr
I started jacking that way once and stopped when the deflection got my attention. I worried about bending the axle?? Mine is a 54 with the stock 223.
Old Jan 29, 2023 | 12:51 PM
M2HB's Avatar
M2HB
If I am jacking up a straight axle, I place the floor jack near where the leaf spring mounts. I try to leave enough room to place a jack stand on, or near, the spring mount location.
Old Jan 29, 2023 | 05:30 PM
hooler1's Avatar
hooler1
I jack up mine the same way as 1949F1. I just put the trolly jack under the center of the front straight axle and pump away. To make it easier and consistent I measured and marked the exact center of the front axle with a paint pen. I have noticed mine deflects a little too, but I figure it will flex back out when I let it down again. After the front of the truck is as high as I need it, I slide each jack stand under the axle between the the leaf spring U bolts. But I like 1949's idea of putting them under the king pins and will try that.
Old Jan 30, 2023 | 08:16 AM
bobj49f2's Avatar
bobj49f2
I do what the other say when using a floor jack. I have '48-52 trucks but I'm certain there isn't much difference from the newer trucks.
I have a two post lift in my shop and I position the lift pads as close to the spring mounts as I can. The frames on this truck are very stout and I don't think there's much worry about bending anything. When lifting my '49 F-2 I have to use the truck adapters for the lift turned all of the way out and then the lifts arms are up against the bottom of the running boards. Always good idea when using a lift is to the wheels off the ground a few inches and give the front and back bumpers a bounce to make sure everything is balanced. My wife has a '16 Fusion, that car is a joy to position the lift arms under. Most of the underside of the car is plastic, only one place to position the lift pads in each corner. Impossible to get a floor jack under the car.
Old Jan 31, 2023 | 09:38 AM
Harrier's Avatar
Harrier
I use the front axle as well. Then I put my jack stands usually on the frame just behind the spring perches. Putting them under the axle is a good idea to get a little more height.
Now for my truck, I can get under it with a creeper without jacking it up.
I refrained from replying because I wasn't sure if the axle was a great place, but it sounds like this is what others do. Since everyone should use jacks stands at all times, you aren't leaving the pressure on the axle.
My dream is to have a lift.
Old Jan 31, 2023 | 10:14 AM
bobj49f2's Avatar
bobj49f2
I don't see what the concern would be for using stands under the axles. The two majors parts of the vehicle that takes the most beating is the axles and suspension. Gently lowering the weight on to axles isn't going to do any damage. Also, if you need to support the truck at another spot to do suspension work placing the stand as close to the frame spring mounts is another good spot. Look at the underside of these trucks, they're made of pretty heavy metal. It would take a lot to bend them or cause damage. Now if you had the bed filled to capacity and tried to support the truck by the frame you might cause some damage. It wouldn't be a good idea to try to left the truck with a full load in any case.
Now newer vehicles are an entire different scenario. As with my wife's car you have to be extremely carful where you lift and support the car, it's build of thin metal and plastic.
That was my dream for over 40 years. I bought a used Manitowoc two post lift for $2000, worth every penny and it paid for itself within a month. Your back and knees will thank you.
Old Jan 31, 2023 | 04:15 PM
hooler1's Avatar
hooler1
Mine too. Along with having a nice shop building to put it in. But at least I got one dream to come true. Just being able to have an old Ford truck. Til a shop building comes along (if ever) its just getting creative to work on it in my garage, driveway, or even where I garage it in a storage unit.
Old Jan 31, 2023 | 04:47 PM
Harrier's Avatar
Harrier
I really enjoy my new shop. I'm still working on it, but it's great. My son in law had some noise coming from his truck. So be brought it into the shop and quickly diagnosed a wheel bearing.
We were able to get it changed quickly It was so nice to have it inside with all my tools handy. Next big things are a lift, heat, and organization.
Old Mar 22, 2023 | 06:13 PM
turnrjr's Avatar
turnrjr
Just purchased this accessory for my floor jack at Harbor Freight. Now I wish I had it through the restoration. It’s safe, easy to use and fast.
Aftrmidnite
General Automotive Discussion
Jul 19, 2010 12:14 PM
Flywest
13
Jan 16, 2007 01:51 PM
cwgoff
1997 - 2003 F150
Jul 12, 2004 08:40 PM
Jupiter Coyote
1997 - 2003 F150
Apr 20, 2004 01:54 PM
jrs_big_ford_f150
Garage & Workshop
Feb 14, 2003 10:21 AM
