Upper oil pan leak(just like mine) & Arod says engine needs pulled..
Old Jan 16, 2023 | 06:59 AM
zeroo's Avatar
zeroo
My 2022 bleeds from exactly the same spot arod point out in this video. I’ve opted to just spray with brake cleaner every time i change oil. The leak is right above oil filter housing where started is. My understanding you could pull all the front end components off to get to it. Arod is saying you have to pull engine..WTH?
Here is mine.
Old Jan 16, 2023 | 07:20 AM
speakerfritz's Avatar
speakerfritz
Taker it to a truck center.
mine was done with out pulling the engine.
Old Jan 16, 2023 | 08:24 AM
zeroo's Avatar
zeroo
What year is your truck?
Old Jan 16, 2023 | 08:37 AM
ToMang07's Avatar
ToMang07
To do it right, yes you have to pull the engine.
Old Jan 16, 2023 | 09:23 AM
speakerfritz
2019.
Old Jan 16, 2023 | 09:29 AM
senix's Avatar
senix
would this not be covered under the 5 year/100K warranty.
Old Jan 16, 2023 | 09:51 AM
speakerfritz
yes
mine was
Old Jan 16, 2023 | 10:03 AM
zeroo's Avatar
zeroo
yes, and my truck is covered for 150k on this. But I’m at 60k miles and will probably dump it at 100k. As long as it doesn’t get worse I’ll just keep spraying it off, especially if ford wants to do a cab off. I have had many superdutys and have had no major repairs done. Not sure any of the dealers I deal with I would want doing a cab off.
Old Jan 17, 2023 | 10:43 AM
jollyrogr's Avatar
jollyrogr
Is the 21 different from previous years?
Old Jan 17, 2023 | 11:36 AM
FishOnOne's Avatar
FishOnOne
Yes... because of the new variable capacity oil pump on '20 + model years now hangs lower than the block which now means you can't slide the oil pan off with the engine in the truck. Wouldn't be an issue if Ford could design a quality seal on the oil pan.
Old Jan 17, 2023 | 11:42 AM
zeroo's Avatar
zeroo
Yea, I’ll just keep spraying brake cleaner….
but will get it fixed before I trade it off. Ford needs to absorb this cost.
Old Jan 18, 2023 | 02:20 PM
jollyrogr's Avatar
jollyrogr
That's too much to ask apparently...
They've got time to design battery powered junk though.
Old Jan 18, 2023 | 02:25 PM
zeroo's Avatar
zeroo
Plus I think in 2021 they went from the silicone gasket to an o-ring.
Old Jan 18, 2023 | 03:26 PM
jollyrogr's Avatar
jollyrogr
I believe that was a 2020 change
Old Jan 18, 2023 | 03:29 PM
JoeUser's Avatar
JoeUser
I sure hope so. I'll take a peek at mine and see if I see any seeping...
