2021 F450 tuning and CP4 longevity
Old Jan 6, 2023 | 07:51 PM
Dustin F450's Avatar
Dustin F450
Will the CP4 in the 2021 6.7 support 50-100hp tune from AMDP? Will it tax it to the point of failure?
thanks,
Old Jan 6, 2023 | 10:06 PM
speakerfritz's Avatar
speakerfritz
I thought the limit was 800hp before replacing the plunger and top hats but this article says it’s 700hp.
granted a tune with out upgraded top hats and upgraded injectors won’t give you a very big wow factor.
https://www.drivingline.com/articles...-power-stroke/
Old Jan 8, 2023 | 07:39 AM
Absolution's Avatar
Absolution
thanks,
Most you'll see is a drop in line pressure from not being able to keep up with volume. There shouldn't be any ill effects as far as life expectancy. If you ever had a 7.3/6.0 kinda think of it like an hpop, It's a pump that moves fluid with a device that regulates flow (Ipr/mrop). If it can't keep up it will just fall on its face, granted I wouldn't constantly let it drop to nothing. But it will tell you if a tune was too much.
Edit: by the way, when you get time with amdp I'd love to hear your experience. Especially with the transmission tunes.
96SD
Nov 26, 2022 10:32 AM
jackstar
Dec 24, 2020 10:00 PM
Jessef250
Sep 30, 2011 12:41 AM
99hunter
Jan 7, 2010 10:10 PM
