abrupt change in fuel residue in fuel sample
At 188474 miles the analysis came back with 5.9% fuel dilution and 9.7 cST at 100C.
at 194667 miles fuel was 3.6% with viscosity at 8.7
at 203166 miles fuel was 4.3% with viscosity at 9.4
Previous to the 188474 analysis the fuel was less than 1 since new
Dealer says this is normal. I find it disturbing that there was a step change after 11 years.
Oil has been changed by the dealer with the exception of a couple changes at the first year of service.
Oil is motorcraft 10W-30
I am no expert on the metal and additive levels but they all seem to be consistent. I had a batch of new oil analyzed and use that for comparison.
Do I have a problem?
Does the truck idle a lot? When do you change the oil? Provide some details here so the community can respond.
I have found my 6.7 to make oil...I fill oil on the low side (very tip of the dip stick) and watch it quickly creep up the dip stick within a few thousand miles. so yes...there is some fuel dilution into the oil going on.
but...ford has a clever invention to hide this so that most folks dont know whats going on....as the oil level rises due to fuel dilution..there is a hose connected to you CCV that sucks oil into your inlet...so you are continually burning off the excess rise on fuel diluted oil. but...there is a back order of 500 engine blocks for blown motors due to oil starved internals that tells me this whole thing is a risk transferance to the customer.
as previously stated decide what oil weight is good for the service duty you use. obviously, weather temps play a factor in the oil choice..but the thickest oil possible within the weather range will offer a greater buffer from fuel dilution. 5W30 or 5W40 may not be the best option. you definitely want to switch to severe duty schedule.
The 2012 I had, the last oil change showed <0.5% fuel dilution over 6200 miles. If the next change showed 5.9% I would be worried as that is a HUGE increase in fuel. It would be akin to someone dumping a cup of fuel into the engine block.
Avoid biodiesel but have used a few tankfuls in the past due to that is all they sold in California where I refueled.
Mostly highway miles. No excessive idling. Always drive long enough to get temps up to normal.
Have Banks iDash monitors. Always allow regen to finish if underway.
I just completed a 2500 mile trip after the last oil change. I will have the oil changed and analyzed. What other options do I have for analysis other than LubeWatch?
I had good fuel mileage on the trip (from 17 mpg to over 19mpg) That seems to be the same since the truck was new.
