H&S upper intake product
Old Dec 28, 2022 | 07:30 AM
speakerfritz's Avatar
speakerfritz
https://hs-motorsports.com/products/...gn=sag_organic
they claim that is a direct replacement with no tuning needed. But, I see two 1" passages not used on the new product that was on the old OEM solution...anyone have any idea what those holes at 3:00 and 9:00 are and if that will throw a code.
Old Dec 28, 2022 | 07:34 AM
speakerfritz
Old Dec 28, 2022 | 11:16 AM
speakerfritz
Reply from tech support
……………………………….Hello, Those passages are anti-noise chambers in the intake, blocking them off has no effect on the engine whatsoever. Please let us know if you have any more questions. Thanks!
Old Dec 28, 2022 | 02:29 PM
Pugga's Avatar
Pugga
That cleans up the engine bay pretty nicely! Not sure it's something I'd spend almost a grand on, but sure looks nice and clean.
Old Dec 28, 2022 | 02:40 PM
Overkill2's Avatar
Overkill2
Yeah I was on their website in the past and that was out of stock... Pretty slick. If I hit the lottery, I'll grab one....
Old Dec 28, 2022 | 03:26 PM
acdii's Avatar
acdii
One thing is certain, it would make cleaning the soot out of the lower intake a breeze. Getting that upper out with the bolts that won't come out and get in the way is a royal PITA!! That alone would be worth it if you plan to keep the truck a long time and not delete it. I plan to clean mine out every 50K or so. I normally am not one for a catch can on a street vehicle, but I am for this engine, along with the CCV mods to help keep the oil out the lower so the soot doesn't gum up and coke.
Old Dec 28, 2022 | 06:52 PM
Overkill2's Avatar
Overkill2
I do plan on keeping my truck for a long time. She's paid off in two more payments in 2023. I'm not deleting because I live in a CARB state... she's been running real good with almost 100k miles now.
Going to be taking the intake manifold off soon for the DPK kit install... will take pics and want to clean since it's off...
I installed my Mishimoto oil catch can about 48k miles ago... Dec. 2019.
Old Dec 29, 2022 | 07:35 AM
speakerfritz
I don’t see a MAP sensor port on this….
Old Dec 29, 2022 | 07:47 AM
Overkill2's Avatar
Overkill2
They have a port welded on the left side of the intake... I'd assume that's it...
Old Dec 29, 2022 | 07:57 AM
speakerfritz
Correct.
since MAP is pressure that should work. Don’t know if that will catch more ccv oil being almost horizontal vs the stock vertical position.
Old Dec 29, 2022 | 08:52 AM
WK15's Avatar
WK15
Just a question here. For the price of this product. Would it be more prudent to just a buy a full piping kit for a few more dollars?
Old Dec 29, 2022 | 09:17 AM
speakerfritz
a few bucks
Old Dec 29, 2022 | 09:32 AM
acdii's Avatar
acdii
I was going to ask that you update on how you got the upper out with the bolts being still attached to the upper, but see yours is a 16, which, is like the 12 I had and weren't an issue, but are a PITA on the 19. I was not able to remove the upper from under the cowl and had to work around it.
The lower is still in play though since it has the inlet for the EGR. The full kit is the upper and CAI only.
Old Dec 29, 2022 | 09:39 AM
speakerfritz
Originally Posted by acdii
I was going to ask that you update on how you got the upper out with the bolts being still attached to the upper, but see yours is a 16, which, is like the 12 I had and weren't an issue, but are a PITA on the 19. I was not able to remove the upper from under the cowl and had to work .
you cut some 1/2 hose to 1/2 in length. Slice each on one side so you can open the hose . Put one under the head of each bolt . The upper intake will slide right out since no bolts will catch on anything .
Old Dec 29, 2022 | 09:41 AM
acdii's Avatar
acdii
You know, sometimes it is the simplest things that you never even think about that work. SMDH
