2020 6.7 running hot
Old Dec 23, 2022 | 05:51 AM
Stone250's Avatar
Stone250
1st Gear
20/20 F-250 idles fine pulling a load down the road it's -15° truck keeps saying running hot pull over wait a couple minutes truck starts right back going as long as I stay under 40 miles an hour truck won't run hot
Old Dec 23, 2022 | 07:04 AM
Overkill2's Avatar
Overkill2
Stuck closed primary thermostat maybe?
Old Dec 23, 2022 | 09:10 AM
helifixer's Avatar
helifixer
unless there was a change in design the 6.7l has a dual thermostat for the main system. both being stuck shut would seem unlikely.
Old Dec 23, 2022 | 09:12 AM
Overkill2's Avatar
Overkill2
Unfamiliar with the thermostat, is that all the MYs of the 6.7?
Old Dec 23, 2022 | 09:37 AM
The Bone's Avatar
The Bone
I bet it could be a faulty temp sensor.
Old Dec 23, 2022 | 10:14 AM
helifixer's Avatar
helifixer
motorcraft RT1249 2011 through 2022
Old Dec 23, 2022 | 11:14 AM
Just Chilling's Avatar
Just Chilling
Do you have a snowplow on the front? I have seen that block airflow and make a vacuum up there.
My fan has come on already when running down the road with a plow on.
Old Dec 23, 2022 | 11:35 AM
Overkill2's Avatar
Overkill2
Always said you're never too old to learn something...
My Meyer 8 foot Lot Pro, no matter where I place the blade or angle it, gets my truck hotter, both coolant and oil, but not enough to cause a de-rate or CEL.
It's 32 inches high and my truck simply does not like it. I've tried just dangling it above the ground and still not good... Angling it doesn't help.
She gets just under 220 degrees...
Old Dec 23, 2022 | 11:37 AM
ToMang07's Avatar
ToMang07
I've driven in July in 80-90*F weather with a plow on and never saw higher than normal temps.
Old Dec 23, 2022 | 11:39 AM
ToMang07's Avatar
ToMang07
While you're correct, if the primary side is not functioning this could be the culprit.
Old Jan 5, 2023 | 09:04 PM
donovan's Avatar
donovan
I towed in 115 degree 10k pound trailer 7 percent grades. If the system is working it works well. I would think thermostat or low fluid. Thermostats are cheap.
Old Jan 7, 2023 | 09:54 AM
HRTKD's Avatar
HRTKD
@Stone250 hasn't logged in since the 24th. Since it doesn't sound like his probably was going away on its own, it would be nice to hear an update.
NedFletcher
Mar 6, 2022 11:18 AM
jhaas63
May 28, 2013 07:54 PM
3Mike6
N. California Chapter
Jan 21, 2010 12:44 PM
5 Star Tuning
South Carolina Chapter
Sep 2, 2008 01:44 AM
husker
Kansas Chapter
Jul 19, 2006 09:56 PM
