fuel tank pressure and overflow
Old Jun 16, 2022 | 10:56 AM
Black Beauty 250's Avatar
Black Beauty 250
Trailering
truck usually runs very smooth- very few miles on rebuilt engine- infrequent use
truck ran rough when i took it out last week- low on power!- managed to get it home but when i turned it off in driveway, i realized gas was being forced out of filler tube for rear fuel tank
am clueless as to where to start
Old Jun 16, 2022 | 11:03 AM
rla2005's Avatar
rla2005
Dozens of threads with the same issue. It's the dreaded cross-flow issue these trucks are known for. The tank that is getting filled has a bad check or shuttle valve in the fuel delivery module. The fix is usually to replace the entire FDM.
Old Jun 16, 2022 | 03:04 PM
Scndsin's Avatar
Scndsin
Cross flow doesn't normally cause running issues. You might want to run codes & maybe check pressure at the rail before going with the module.
Particularly if it runs rough on both tanks.
kgrice09
17
Oct 19, 2022 04:35 PM
comsupany
Oct 3, 2017 09:02 AM
Jarrett Campbell
Oct 11, 2015 10:46 AM
rogersdan
Jul 2, 2009 10:49 AM
1994_F150_302M
Sep 30, 2005 04:18 AM
