1956 F100 3 speed transmission Dissasembly???
Old May 22, 2022 | 01:16 PM
Glens67's Avatar
Glens67
How do you get the reverse shaft pin and counter cluster shaft pin out??? Light Duty 3 speed transmission.
Old May 22, 2022 | 02:13 PM
pintoplumber's Avatar
pintoplumber
Is this the tranny with the cover on the side? The head of the pin is under the cover. Drive it back out from the other side. I’m reassembling mine right now, I’ll take a picture.
Old May 22, 2022 | 02:32 PM
Glens67's Avatar
Glens67
Yes Cover on the side. Is that the Reverse pin? and the Counter Shaft pin. I'm talking about the Shaft pins. Is that one long pin?
Thanks
Glen
Old May 22, 2022 | 03:06 PM
Glens67's Avatar
Glens67
I got it!!! I thought there were 2 Pins...
Thanks!!! @pintoplumber
@pintoplumber
pintoplumber is online now
Old May 22, 2022 | 03:34 PM
pintoplumber
One long pin. Mines overdrive, but the main case is the same.
Old May 22, 2022 | 03:37 PM
pintoplumber
Also, if you’re going to remove the cluster gear, (it seems like everything you do involves removing the cluster gear) cut a wooden dowel to insert as you’re removing the shaft.
Old May 22, 2022 | 05:44 PM
Glens67's Avatar
Glens67
Thanks again!!!
Glen
Old May 22, 2022 | 06:00 PM
pintoplumber
I see you’re a drag racer. I dabble in it a little. Here’s one from 2013.
Runner up
Old May 23, 2022 | 10:45 AM
Glens67's Avatar
Glens67
Good Job!!!
Old May 23, 2022 | 10:49 AM
Glens67's Avatar
Glens67
I have been running that 67 GT since 1989 well over 10,000 passes...
Old May 26, 2022 | 12:49 PM
Glens67's Avatar
Glens67
Where do I get a rebuild kit for this transmission???
Old May 26, 2022 | 02:56 PM
pintoplumber
vanpeltsales.com. I think they’re in Ohio, never bought anything off of them, but a lot of people recommend them.
Old May 5, 2026 | 03:45 PM
Dgriffin's Avatar
Dgriffin
1st Gear
Same issue, excuse if this is a redundant question
[QUOTE=pintoplumber;20415025]One long pin. Mines overdrive, but the main case is the same.
Any chance you can explain to me how to remove this pin ? Rebuilding the same transmission, I don’t see anywhere to punch it from the opposite side, Thanks for any help
Old May 5, 2026 | 07:23 PM
pintoplumber
Your question timing is perfect. My transmission is on the work bench right now. The pin hole is on the bottom of the transmission left bottom side of this picture. The pin head is shown on the bottom right of the 2nd picture.
This is the bottom side of the transmission. Use a pin punch and drive the pin up and out. Side cover must be off.
Old May 7, 2026 | 08:26 AM
pintoplumber
@Dgriffin Any success yet?
66low
Dec 29, 2014 12:04 PM
1948 F1dude
Ford Truck Parts for Sale
Dec 7, 2014 09:20 PM
Daddyo's garage
WTB - Parts & other
Nov 2, 2013 11:08 AM
jonmark1985
13
Mar 18, 2012 09:13 PM
truck35
Oct 17, 2001 02:24 PM
