1989 f-250, no gas to cylinders
Old Apr 13, 2022 | 04:37 PM
ggerstner's Avatar
ggerstner
1989 Ford F-250 w/5.8 351 W
Not getting gas to cylinders
I have:
· 40 lb Fuel pressure on the fuel bar
· Replaced ½ fuel injectors
· Replaced Fuel Pressure regulator
· Replaced pumps
· Replaced Fuel filters
· Replaced solenoid
It will fire and run when fed starter fluid
It will not start with the key in the ignition, I am using a push start between the batter and starter solenoid.
Looking for some guidance on what to do next.
Old Apr 13, 2022 | 05:16 PM
My4Fordtrucks's Avatar
My4Fordtrucks
You might be able to get some noid lights from the local parts store loaner/rental program. You need to determine if the computer is “firing” the injectors.
Old Apr 17, 2022 | 12:14 PM
ggerstner's Avatar
ggerstner
Update
I pulled out the ECU. It had water damage and mud in it.
I have replaced it.
I now have no pressure at the injector bar.
I am going to pull the ECU and reseat the connection. Definitely scratching my head
Old Apr 17, 2022 | 06:54 PM
My4Fordtrucks
No pressure at the fuel rail? Does the in-tank pump run for a couple seconds and then shut off when the key is turned to “run?”
Old Apr 17, 2022 | 07:10 PM
ScottinAZ's Avatar
ScottinAZ
the ECU controls the pumps, igintion and injector firing. Since you have none of the above it seems, the ECU and associated power inputs (to ensure the ECU has juice to power up) is where you need to start. You can crank it all day long with a remote start switch, but this isnt carbureted with simple 12v input ignition. If the computer isnt firing the injectors, then the engine will never fire up. (learned this the hard way myself, had a blown MAXI fuse that powers the ECU....)
Old Apr 18, 2022 | 12:51 AM
Skitter302's Avatar
Skitter302
Reading the First post My guess was PCM. Now I'm assuming that the New PCM has a trigger wire in the wrong spot. Just for fun I would set the key to the run position and jump the Fuel relay. Then use the push button to crank it to life. If that doesn't work then you have more issues between the distributor and the EEC.
Donhuff
Apr 11, 2016 10:10 PM
louand
24
Aug 5, 2015 09:19 PM
Mike58
Modular V10 (6.8l)
33
Jun 6, 2012 02:33 PM
phillips91
1978 - 1996 Big Bronco
May 28, 2010 08:44 PM
