Changing Gear Ratio in Rear End to 3.55 on 7.3L Godzilla
Old Apr 6, 2022 | 02:45 PM
Ratherbefishing's Avatar
Ratherbefishing
Trailering
Hello: Any experience or thoughts on changing rear end to a 3.55 ratio from the stock option 3.77 for the 7.3L Godzilla? The motor has excellent low end torque, love to get a couple more MPG. With the 10spd transmission, this shouldn't be an issue affecting my drivability.
Old Apr 6, 2022 | 02:49 PM
Pugga's Avatar
Pugga
My thought is you'd never recoup the cost of a gear swap with MPG savings. With the 10 speed, I wouldn't expect any noticable difference in MPG going from 3.73 to 3.55. That's not much of a jump, especially when you have the 10 speed transmission to start with. Best bet for better MPG's is modifying your driving habits.
Old Apr 6, 2022 | 02:59 PM
wheelerfreak's Avatar
wheelerfreak
Pretty much what he just said. If it’s 4x4 you have to do both diffs and I can’t see the cost would ever make that small of a gear change worth it. Just be easy on the throttle and don’t drive aggressively or fast
Old Apr 6, 2022 | 03:05 PM
Jmo371's Avatar
Jmo371
you would be saving like 75 RPM at 75MPH.....
https://spicerparts.com/calculators/...rpm-calculator
I regarded my old 2016 F-150 3.5 EB FX4 from 3.31's to 4.10s. It was a few sheckles shy of 3 grand installed.
Old Apr 6, 2022 | 03:14 PM
Bldrinker's Avatar
Bldrinker
Waste of Time and money. If you got extra of both go for it.
I did gears on my 6.4 Hemi. Went from 4:10 to 4:88. Was there a difference yes. Was there a $3000 difference nope.
what you will pay to do gears buys a whole bunch of fuel. You might gain .5mpg
Old Apr 6, 2022 | 03:17 PM
Jmo371's Avatar
Jmo371
You could gain more then that by driving habits.....and keeping the highway speeds reasonable, fuel consumption really falls off the face of the earth above what, 72-75?
Old Apr 6, 2022 | 03:45 PM
Keith Griffin's Avatar
Keith Griffin
I've found that driving 65-70 on the highway (even in 75MPH speed limits) gets me the best mileage on my 2017 F-250. If I jump up to 75-85, forget it. Yeah, I can keep up with anyone on the road, but when my mileage goes from 17-20mpg down to 14-15mpg, it's not worth the extra MPH to get there faster. I just leave a little earlier or plan on arriving a little later.
Old Apr 6, 2022 | 04:25 PM
HorizontalHunter's Avatar
HorizontalHunter
Agreed, and make sure that you are hand calculating the mileage.
I made a 200 mile highway runs with a small amount of city driving. My actual MPG was 18.3 mpg while the dash monitor said 15.2mpg. I was surprised that it was that far off. 7.3L with 4.30 gears.
Bob
Old Apr 6, 2022 | 05:06 PM
Jmo371's Avatar
Jmo371
Bob
that's pretty good for a 3/4 ton truck, what was your average Highway speed?
Old Apr 6, 2022 | 05:12 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
3.55 from 3.73 is such a small change, it would absolutely not be worth fooling with, not a good ROI on that change.
Old Apr 6, 2022 | 05:16 PM
NeverboughtanFseries's Avatar
Absolutely a big waste of time and money and probably won't see any benefit anyway.
Old Apr 6, 2022 | 05:21 PM
HorizontalHunter
I had the cruise set at 65 mph.
Old Apr 6, 2022 | 06:42 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I gained 0.7 mpg just by using non-ethanol gas the last couple tanks.
Old Apr 6, 2022 | 07:59 PM
Joe T's Avatar
Joe T
I would run some light weight street tires with an eco rating.
I doubt you would ever make up going to 3.55. Maybe 3.31 would help.
Old Apr 6, 2022 | 08:13 PM
Ratherbefishing
Trailering
I would like to thank all those that replied. Special thanks to Jmo371, who provided the link with the Spicer Parts RPM calculator. Easy to use and provides number creditability that went with the forum consensus.
